VDX6740-24 and base switch license
  • 9 July 2018
  • 3 replies
  • 1061 views
Hello,
Does VDX6740-24 by default come with 2x40G ports license included in the base switch license or it has to be ordered separately? I recall in VDX6740T-1G I can see two 40G in the base switch license, but with VDX6740-24 it says None.
Thank you.
You must to buy a Licence:
BR-VDX6740-2x40G-POD
2-port 40 GbE PoD license for Brocade VDX 6740 and 6740T
Userlevel 1
VDX6740T-1G has two base licence for 40G by default so that it can be used in a VCS fabric as ISL cannot be formed with 1G ports
Thank you!
Reply
