Solved
Cisco Trunk Interface with Extreme NAC
  • 12 October 2020
  • 22 replies
  • 220 views
Userlevel 1
Dear All
I’m trying to enable Extreme NAC for Cisco switches. It works fine for Clients on Access Ports. For Accesspoints (local breakout), I’m trying to get a trunk interface with management vlan untagged and data VLANs tagged.
For XOS Switches, I would create a Role with the needed VLAN Egress config
But I cant enforce this role configuration to Cisco switches
How can I achieve that for Cisco switches with Extreme NAC?
icon
Best answer by michael.klaus 15 October 2020, 13:53
Hi Miguel
Yes sure, I can share my cisco config. In the meantime, I tested NEAT as well and it seems to be easier than using macro.
Macro
conf t
no macro auto global control device
no macro auto global control trigger
macro auto global processing
macro auto execute AP_TRUNK  {
if [[ $LINKUP == YES ]]
then conf t
default interface $INTERFACE
Description AP_TRUNK
macro description $TRIGGER
switchport trunk allowed vlan ##VLAN-LIST##
switchport trunk native vlan ##VLAN##
switchport mode trunk
spanning-tree portfast trunk
macro auto processing
exit
fi
if [[ $LINKUP == NO ]]
then conf t
description NAC
no switchport trunk allowed vlan
no switchport trunk native vlan
switchport mode access
authentication control-direction in
authentication event server dead action authorize
authentication event server dead action authorize voice
authentication event server alive action reinitialize
authentication host-mode multi-host
authentication order mab dot1x
authentication priority dot1x mab
authentication port-control auto
authentication periodic
authentication timer reauthenticate server
authentication violation restrict
mab
snmp trap mac-notification change added
snmp trap mac-notification change removed
dot1x pae authenticator
dot1x timeout tx-period 10
no macro description $TRIGGER
exit
fi
int range ##INTERFACE-RANGE##
Radius Attribute: Cisco-AVPair=auto-smart-port=AP_TRUNK
NEAT
cisp enable
template AP_TRUNK
switchport trunk encapsulation dot1q
switchport trunk native vlan 100
Radius Attribute: Cisco-AVPair=interface-template-name=AP_TRUNK
Comparison Smart Port vs. Macro:
best regards
Michael
View original
Userlevel 6
Badge +1
Michael,
For cisco switches you cannot enforce a Role from the policy domain.
You must send standard and Cisco radius attributes only.
The standards are those in the Policy Mapping and the cisco specific are to be defined via the Custom/Organization fields in Policy Mapping and/or via the “configure device/Radius attributes to send” from the switch in the NAC group Engine:
Mig
Userlevel 1
Hi Miguel
I understand that I have do do it via Radius attribute. But I don’t understand where I can define the native (untagged) and the list of allowed vlans.
Userlevel 6
Badge +1
Michael,
For Cisco switches to understand the dynamic VLAN provisioning there is some more things to do.
Have a look here:
As you’ll see this part is specific to Cisco equipment.
On the Extreme side you’ll have to send this (aligned with your config):
There is some more work ...:wink:
Mig
Userlevel 6
Badge
Hello Michael,
there is a official Extreme Guide for the integration of Cisco into XMC and NAC.
Please see here:
https://gtacknowledge.extremenetworks.com/articles/Q_A/Where-can-I-find-a-Cisco-switch-and-Extreme-Management-Center-Integration-Guide
Regards
Stephan
Userlevel 1
Thanks for your replys.
So my first step is to get it running to convert a port from access to trunk. Dynamic VLAN is my next stept.
Based on the documentation, I did following configuration.
Radius attribute configuration:
Policy mapping:
Set the custom 1
The result is that in the “End-Systems” tab it looks fine with the defined attributes (cisco-av-pair is set correctly)
the config evaluation tool looks fine as well
But on the switch the interface remains as access port. So I did a debug on the switch and a tcp dump on the NAC engine. In both of them, I can’t see this atrribute.
Tcp Dump NAC Engine
root@itbzs951:~$ tcpdump "host 172.16.1.99" -v
tcpdump: listening on eth0, link-type EN10MB (Ethernet), capture size 262144 bytes
08:11:14.080546 IP (tos 0x0, ttl 253, id 45515, offset 0, flags [none], proto UDP (17), length 286)
    172.16.1.99.datametrics > itbzs951.rzb.ch.radius: RADIUS, length: 258
        Access-Request (1), id: 0x4f, Authenticator: 685e68a2ba54bbdba948fcb175c862d5
          User-Name Attribute (1), length: 14, Value: 008077515afa
          User-Password Attribute (2), length: 18, Value:
          Service-Type Attribute (6), length: 6, Value: Call Check
          Vendor-Specific Attribute (26), length: 31, Value: Vendor: Cisco (9)
            Vendor Attribute: 1, Length: 23, Value: service-type=Call Check
          Framed-MTU Attribute (12), length: 6, Value: 1500
          Called-Station-Id Attribute (30), length: 19, Value: 34-F8-E7-C4-01-83
          Calling-Station-Id Attribute (31), length: 19, Value: 00-80-77-51-5A-FA
          Message-Authenticator Attribute (80), length: 18, Value: .Q......c.H.....
          Unknown Attribute (102), length: 2, Value:
          Vendor-Specific Attribute (26), length: 49, Value: Vendor: Cisco (9)
            Vendor Attribute: 1, Length: 41, Value: audit-session-id=AC1001630000009C7FB1A5B2
          Vendor-Specific Attribute (26), length: 18, Value: Vendor: Cisco (9)
            Vendor Attribute: 1, Length: 10, Value: method=mab
          NAS-IP-Address Attribute (4), length: 6, Value: 172.16.1.99
          NAS-Port-Id Attribute (87), length: 20, Value: GigabitEthernet0/3
          NAS-Port-Type Attribute (61), length: 6, Value: Ethernet
          NAS-Port Attribute (5), length: 6, Value: 50103
08:11:14.128037 IP (tos 0x0, ttl 64, id 57966, offset 0, flags [none], proto UDP (17), length 65)
    itbzs951.rzb.ch.radius > 172.16.1.99.datametrics: RADIUS, length: 37
        Access-Accept (2), id: 0x4f, Authenticator: 9c553fbf49b3d282e6125af6c230c862
          Tunnel-Type Attribute (64), length: 6, Value: Tag[Unused] VLAN
          Tunnel-Private-Group-ID Attribute (81), length: 5, Value: 999
          Tunnel-Medium-Type Attribute (65), length: 6, Value: Tag[Unused] 802
08:11:15.170597 IP (tos 0x0, ttl 253, id 45526, offset 0, flags [none], proto UDP (17), length 252)
    172.16.1.99.sa-msg-port > itbzs951.rzb.ch.radius-acct: RADIUS, length: 224
        Accounting-Request (4), id: 0x5e, Authenticator: 390556e6c058ae69e9f8e4daa2ee3993
          Vendor-Specific Attribute (26), length: 19, Value: Vendor: Cisco (9)
            Vendor Attribute: 1, Length: 11, Value: vlan-id=999
          Acct-Session-Id Attribute (44), length: 10, Value: 00000071
          Acct-Status-Type Attribute (40), length: 6, Value: Start
          Event-Timestamp Attribute (55), length: 6, Value: Tue Oct 13 08:11:15 2020
          Acct-Delay-Time Attribute (41), length: 6, Value: 00 secs
08:11:15.171425 IP (tos 0x0, ttl 64, id 58193, offset 0, flags [none], proto UDP (17), length 48)
    itbzs951.rzb.ch.radius-acct > 172.16.1.99.sa-msg-port: RADIUS, length: 20
        Accounting-Response (5), id: 0x5e, Authenticator: 9268a78ff22e9f4a1253178622130e1c
Debug Switch:
Oct 13 08:11:13.165: dot1x-ev:[Gi0/3] Interface state changed to UP
Oct 13 08:11:13.169: dot1x-ev:DOT1X Supplicant not enabled on GigabitEthernet0/3
Oct 13 08:11:13 UTC+1: %LINK-3-UPDOWN: Interface GigabitEthernet0/3, changed state to up
Oct 13 08:11:14.070: AAA/AUTHEN/8021X (00000000): Pick method list 'default'
Oct 13 08:11:14.070: AAA/AUTHEN(00000000): There is no General DBReply Method Index details may not be specified
Oct 13 08:11:14.070: RADIUS/ENCODE(00000000):Orig. component type = Invalid
Oct 13 08:11:14.070: RADIUS/ENCODE(00000000): Unsupported AAA attribute hwidb
Oct 13 08:11:14.070: RADIUS/ENCODE(00000000): Unsupported AAA attribute auth-profile
Oct 13 08:11:14.070: RADIUS/ENCODE(00000000): Unsupported AAA attribute aaa-authen-type
Oct 13 08:11:14.070: RADIUS/ENCODE(00000000): Unsupported AAA attribute aaa-authen-service
Oct 13 08:11:14.070: RADIUS/ENCODE(00000000): Unsupported AAA attribute clid-mac-addr
Oct 13 08:11:14.070: RADIUS/ENCODE(00000000): Unsupported AAA attribute target-scope
Oct 13 08:11:14.070: RADIUS/ENCODE(00000000): Unsupported AAA attribute aaa-unique-id
Oct 13 08:11:14.070: RADIUS(00000000): Config NAS IP: 0.0.0.0
Oct 13 08:11:14.070: RADIUS(00000000): Config NAS IPv6: ::
Oct 13 08:11:14.070: RADIUS(00000000): sending
Oct 13 08:11:14.070: RADIUS/ENCODE: Best Local IP-Address 172.16.1.99 for Radius-Server 192.168.105.6
Oct 13 08:11:14.070: RADIUS: Message Authenticator encoded
Oct 13 08:11:14.070: RADIUS(00000000): Send Access-Request to 192.168.105.6:1812 onvrf(0) id 1645/79, len 258
Oct 13 08:11:14.070: RADIUS:  authenticator 68 5E 68 A2 BA 54 BB DB - A9 48 FC B1 75 C8 62 D5
Oct 13 08:11:14.070: RADIUS:  User-Name           [1]   14  "008077515afa"
Oct 13 08:11:14.070: RADIUS:  User-Password       [2]   18  *
Oct 13 08:11:14.070: RADIUS:  Service-Type        [6]   6   Call Check                [10]
Oct 13 08:11:14.074: RADIUS:  Vendor, Cisco       [26]  31
Oct 13 08:11:14.074: RADIUS:   Cisco AVpair       [1]   25  "service-type=Call Check"
Oct 13 08:11:14.074: RADIUS:  Framed-MTU          [12]  6   1500
Oct 13 08:11:14.074: RADIUS:  Called-Station-Id   [30]  19  "34-F8-E7-C4-01-83"
Oct 13 08:11:14.074: RADIUS:  Calling-Station-Id  [31]  19  "00-80-77-51-5A-FA"
Oct 13 08:11:14.074: RADIUS:  Message-Authenticato[80]  18
Oct 13 08:11:14.074: RADIUS:   F0 51 02 09 AD CE DA 95 63 8A 48 91 D1 86 94 F7               [ QcH]
Oct 13 08:11:14.074: RADIUS:  EAP-Key-Name        [102] 2   *
Oct 13 08:11:14.074: RADIUS:  Vendor, Cisco       [26]  49
Oct 13 08:11:14.074: RADIUS:   Cisco AVpair       [1]   43  "audit-session-id=AC1001630000009C7FB1A5B2"
Oct 13 08:11:14.074: RADIUS:  Vendor, Cisco       [26]  18
Oct 13 08:11:14.074: RADIUS:   Cisco AVpair       [1]   12  "method=mab"
Oct 13 08:11:14.074: RADIUS:  NAS-IP-Address      [4]   6   172.16.1.99
Oct 13 08:11:14.074: RADIUS:  NAS-Port-Id         [87]  20  "GigabitEthernet0/3"
Oct 13 08:11:14.074: RADIUS:  NAS-Port-Type       [61]  6   Ethernet                  [15]
Oct 13 08:11:14.074: RADIUS:  NAS-Port            [5]   6   50103
Oct 13 08:11:14.074: RADIUS(00000000): Sending a IPv4 Radius Packet
Oct 13 08:11:14.074: RADIUS(00000000): Started 1 sec timeout
Oct 13 08:11:14.123: RADIUS: Received from id 1645/79 192.168.105.6:1812, Access-Accept, len 37
Oct 13 08:11:14.123: RADIUS:  authenticator 9C 55 3F BF 49 B3 D2 82 - E6 12 5A F6 C2 30 C8 62
Oct 13 08:11:14.123: RADIUS:  Tunnel-Type         [64]  6   00:VLAN                   [13]
Oct 13 08:11:14.123: RADIUS:  Tunnel-Private-Group[81]  5   "999"
Oct 13 08:11:14.123: RADIUS:  Tunnel-Medium-Type  [65]  6   00:ALL_802                [6]
Oct 13 08:11:14.123: RADIUS(00000000): Received from id 1645/79
Oct 13 08:11:14 UTC+1: %EPM-6-POLICY_REQ: IP 0.0.0.0| MAC 0080.7751.5afa| AuditSessionID AC1001630000009C7FB1A5B2| EVENT APPLY
Oct 13 08:11:14 UTC+1: %LINEPROTO-5-UPDOWN: Line protocol on Interface GigabitEthernet0/3, changed state to up
Oct 13 08:11:15.161: RADIUS/ENCODE(00000000):Orig. component type = Invalid
Oct 13 08:11:15.161: RADIUS/ENCODE(00000000): Unsupported AAA attribute clid-mac-addr
Oct 13 08:11:15.161: RADIUS(00000000): Config NAS IP: 0.0.0.0
Oct 13 08:11:15.161: RADIUS(00000000): Config NAS IPv6: ::
Oct 13 08:11:15.161: RADIUS(00000000): sending
Oct 13 08:11:15.161: RADIUS/ENCODE: Best Local IP-Address 172.16.1.99 for Radius-Server 192.168.105.6
Oct 13 08:11:15.161: RADIUS(00000000): Send Accounting-Request to 192.168.105.6:1813 onvrf(0) id 1646/94, len 224
Oct 13 08:11:15.161: RADIUS:  authenticator 39 05 56 E6 C0 58 AE 69 - E9 F8 E4 DA A2 EE 39 93
Oct 13 08:11:15.161: RADIUS:  User-Name           [1]   14  "008077515afa"
Oct 13 08:11:15.161: RADIUS:  Vendor, Cisco       [26]  49
Oct 13 08:11:15.161: RADIUS:   Cisco AVpair       [1]   43  "audit-session-id=AC1001630000009C7FB1A5B2"
Oct 13 08:11:15.165: RADIUS:  Vendor, Cisco       [26]  19
Oct 13 08:11:15.165: RADIUS:   Cisco AVpair       [1]   13  "vlan-id=999"
Oct 13 08:11:15.165: RADIUS:  Vendor, Cisco       [26]  18
Oct 13 08:11:15.165: RADIUS:   Cisco AVpair       [1]   12  "method=mab"
Oct 13 08:11:15.165: RADIUS:  Called-Station-Id   [30]  19  "34-F8-E7-C4-01-83"
Oct 13 08:11:15.165: RADIUS:  Calling-Station-Id  [31]  19  "00-80-77-51-5A-FA"
Oct 13 08:11:15.165: RADIUS:  NAS-IP-Address      [4]   6   172.16.1.99
Oct 13 08:11:15.165: RADIUS:  NAS-Port-Id         [87]  20  "GigabitEthernet0/3"
Oct 13 08:11:15.165: RADIUS:  NAS-Port-Type       [61]  6   Ethernet                  [15]
Oct 13 08:11:15.165: RADIUS:  NAS-Port            [5]   6   50103
Oct 13 08:11:15.165: RADIUS:  Acct-Session-Id     [44]  10  "00000071"
Oct 13 08:11:15.165: RADIUS:  Acct-Status-Type    [40]  6   Start                     [1]
Oct 13 08:11:15.165: RADIUS:  Event-Timestamp     [55]  6   1602569475
Oct 13 08:11:15.165: RADIUS:  Acct-Delay-Time     [41]  6   0
Oct 13 08:11:15.165: RADIUS(00000000): Sending a IPv4 Radius Packet
Oct 13 08:11:15.165: RADIUS(00000000): Started 1 sec timeout
Oct 13 08:11:15.168: RADIUS: Received from id 1646/94 192.168.105.6:1813, Accounting-response, len 20
Oct 13 08:11:15.168: RADIUS:  authenticator 92 68 A7 8F F2 2E 9F 4A - 12 53 17 86 22 13 0E 1C
For me it looks like the NAC engine doesn’t sent the attribute but the attribute is shown in the dashboard.
regards
Michael
Userlevel 6
Badge
Hello Michael.
the Cisco Ethernet Interface Type (= Access or Trunk Port) can’t configured via Radius attributes.
This is independet of the Radius-Server or NAC-Vendor. Cisco does not offer the possibility to switch over via radius protocol.
This is because unlike other vendors, Cisco explicitly distinguishes the port type, while others simply distribute tagged and untagged VLANs. Which is again provided for in the radius protocol.
If you need an dynamic change between Trunk and Access Port and the standard configuration ist Access Port you can enable authentication, and trigger a script on XMC if a access point is is recognized. This script hast to change the Cisco port Config and do an reauth.
Regards
Stephan
Userlevel 6
Badge
Hello Michael,
sorry I saw some of my text is missing on my replay. The following was missing:
Only if you enable “Client Information Signaling Protocol (CISP)” on your switch you can change the port type via Radius according the Network Edge Authentication Topology (NEAT).
Do you have enabled CISP?
Regards
Stephan
Userlevel 6
Badge
Hello Michael,
one additional point. You can try to change “cisco-avpair=” to “Cisco-AVPair=”.
I think there was at least in the past a dependence on upper and lower case letters.
Regards
Stephan
Userlevel 1
Hi Stephan
After changing to “Cisco-AVPair=”, the Ports gets configured as a trunk port. So next step will be to check if I can send native and allowed vlans via Radius attribute.
thanks a lot
Userlevel 6
Badge
Hello Stefan,
with pleasure.
I am not sure if this is possilbe.
According this guide (https://www.cisco.com/c/en/us/td/docs/ios-xml/ios/sec_usr_8021x/configuration/15-e/sec-usr-8021x-15-e-book/sec-ieee-neat.pdf)
“The VSA changes the authenticator switch port mode from access to trunk and enables 802.1X trunk encapsulation and the access VLAN (if any) would be converted to a native trunk VLAN. VSA does not change any of the port configurations on the supplicant.”
it sound there is no vlan change available.  But it’s not 100% clear if an additional vsa can send the vlan IDs. Like you configured for vlan 999.
Do you still these lines in the debug from your switch?
This entry point to the vlan send by NAC.
Best regards
Stephan
Userlevel 6
Badge
Hello Stefan,
I have searched my knowledge base again.
Maybe a interface template is a good workaround.
https://community.cisco.com/t5/security-documents/neat-with-interface-template/ta-p/3642967
Regards
Stephan
Userlevel 6
Badge
Hello Stefan,
I did a quick web search, too. Here is another description regarding NEAT and templates:
https://community.cisco.com/t5/security-documents/ise-secure-wired-access-prescriptive-deployment-guide/ta-p/3641515#toc-hId--100650304
There are some hints in the net about disadvantages concerning the port configuration with NEAT.
for example here: https://community.cisco.com/t5/network-access-control/flexconnect-ap-ise-and-neat/td-p/3302383
It seems that Cisco still has problems to implement a function like "AP Aware" from Extreme.
Best regards
Stephan
Userlevel 1
I solved it with macros because NEATis not available on all switches.
Many thanks for your help.
best regards
Michael
Userlevel 6
Badge
Hello Michael,
nice to hear that you have found a solution.
Do you tigger the macro with the radius attribute “auto-smart-port=event-trigger from NAC, if a appropriate device is authenticated on the access port?
Or how do you enable a macro on the specific port?
Best regards
Stephan Harrer
Userlevel 1
Yes exactly, I use the radius attribute “uto-smart-port=event-trigger” if the mac address is in my Accesspoint End System group.
best regards
Michael
Userlevel 6
Badge +1
Michael,
Could you share the solution?
I’m interested in the config lines for Cisco and the definition of the radius attributes.
Thanks
Mig
Userlevel 1
Hi Miguel
Macro
conf t
then conf t
exit
fi
then conf t
description NAC
mab
exit
fi
NEAT
cisp enable
template AP_TRUNK
best regards
Michael
Userlevel 6
Badge
Hello Michael,
how did you solve authentication with neat and Extreme APs?
Normal for an standard port (printer, pc,...) “authentication host-mode multi-auth” is a good choice to authentication every client separatly (if more the one is present).
If you now plug an AP to the port “authentication host-mode multi-host” is a better choice to authenticate only the first device (=AP). All wireless clients are authenticated via the wireless controller.
If you use “multi-auth” with an Access Point on the port you will see every wireless client twice. From WLAN and from LAN.
I hoped there is a way to change the “authentication host-mode “ via the port template but it seems that’s not possible.
How do you handle that?
Userlevel 1
Hi Stephan
Yes you’re right, you can’t change the authentication host-mode via port template. But with Macros it works. What I’m trying to do is to do all the needed config via port template and just the changing the authentication host-mode with a macro. But up to now I didn’t get i working to send both Cisco-AVPair attributes via NAC. I’m still on my engineering.
best regards
Michael
Userlevel 1
Hi Stephan
It looks like if you use new-style config mode, changing the authentication host-mode is supported via template
Unfortunately, not all of my switches support new-style, so this is not a way for me to go. So I won’t test it.
Up to now i got it working to send both radius attribute (template and smart-port) to the switch. But the switch does not handle both of them
Userlevel 6
Badge
Hello Klaus,
do you know what switch types support the new-style? Maybe I have one for a test.
Userlevel 1
Hi Stephan
If the following command exists it should support new-style. Mine is still in the legacy mode
SW#authentication display config-mode
Current configuration mode is legacy
I don’t now which firmware starts supporting new-style.  My Test Switch WS-C2960CX-8PC-L with 15.2(4)E6 supports new style.
If you do the following, the switch asks you to convert to the new-style.
ITBZC099(config)#template test
ITBZC099(config-template)#access-session host-mode multi-host
This operation will permanently convert all relevant authentication commands to their CPL control-policy equivalents. As this conversion is irreversible and will disable the conversion CLI 'authentication display [legacy|new-style]', you are strongly advised to back up your current configuration before proceeding.
Do you wish to continue? [yes]:
Reply
