Solved
EXOS Stack Switches not archiving in XMC 8.5.0.169
  • 19 October 2020
  • 2 replies
  • 42 views
Userlevel 2
We have 8 sets of EXOS stack switches consisting of 2 X460-G2’s each.
After upgrading to XMC 8.51 the switches will no longer upgrade automatically or manually
The error in the information section of the Inventory log is
Archive Save /World/X460-G2: (172.16.1.104) Version Stamp: Oct 16, 2020 12:00:00 AM - Error Archiving Configuration File. : Do you want to save configuration to primary.cfg and overwrite it? (y/N) Yes Saving configuration primary.cfg  on master .. done! Synchronizing configuration to backup .... done! Slot-1 Rm 104 Switch.2 # extremeprompt                           ^ %% Invalid input detected at '^' marker. Slot-1 Rm 104 Switch.2 # extremeprompt                           ^ %% Invalid input detected at '^' marker. Slot-1 Rm 104 Switch.3 #
XMC version 8.5.0.169
Switch version 22.7.1.2   patch1-24
Thank you for the help
icon
Best answer by Stefan K. 19 October 2020, 16:32
Hello,
this is a known issue in 8.5.0 and it is fixed in 8.5.1. Newer versions of EXOS (I believe 30.6 and newer) are also not affected.
You can also fix it by changing some files on the XMC Host.
Here is an article on this topic: https://gtacknowledge.extremenetworks.com/articles/Solution/000052674
Best regards
Stefan
View original
Userlevel 4
Hello,
Best regards
Stefan
Userlevel 2
Thank you for the response.
I have upgraded to version 8.5.2 and the archive issue has been resolved.
Reply
