Solved
Extreme Management NBI Query Stacking
  • 12 November 2020
  • 11 replies
  • 98 views
Hello,
I am trying to automat some processes for documentation with scripts. I am looking for a NBI query which gives back the model and Serial numbers of a Summit Stack. Can someone help me?
Kind regards
Christoph Schneider
icon
Best answer by StephanH 13 November 2020, 11:25
Hello Christoph,
unfortunately there is no official guide for Python Scripting with XMC. But you can find many official examples under Task -> Scripts and Workflows not only the VLAN scripts.
More examples can also be found here: https://github.com/extremenetworks
For your concrete problem here a small example (quick and dirty) how to query a switch  (XOS only!) and then output the serial numbers.
import re
#Send CLI commands
def sendConfigCmds(cmds):
for cmd in cmds:
cli_results = emc_cli.send( cmd )
if cli_results.isSuccess() is False:
print 'CLI-ERROR: ' + cli_results.getError()
return False
return cli_results.getOutput()
#Use allways a main function in XMC
def main():
commands = []
commands.append("show version")
result = sendConfigCmds( commands )
if result:
result_lines = result.splitlines()
for line in result_lines:
match = re.search("Slot.*?:",line)
if match:
line_parts = line.split()
if len(line_parts) > 2:
print("Serial: " + line_parts[3])
#Start program
main()
Here is what you will see with “show version”:
Slot-1 sw001 # show version
Slot-1 : 800601-00-18 8914N-46722 Rev 18 BootROM: 1.0.2.1 IMG: 22.7.1.2
Slot-2 : 800601-00-18 8912N-46755 Rev 18 BootROM: 1.0.2.1 IMG: 22.7.1.2
Here is the output:
Serial: 8914N-46722
Serial: 8912N-46755
Hope that helps.
View original
Userlevel 6
Badge +1
Christoph,
Try this:
  network {
    devices {
      id
      chassisId
      deviceData {
        sysDescr
Mig
Userlevel 6
Badge +1
Or by IP:
  network {
    device(ip: "10.22.255.255") {
      id
      chassisId
      deviceData {
        sysDescr
Gives
  "data": {
    "network": {
      "device": {
        "id": 377,
        "chassisId": "ABCDEF123456",
        "deviceData": {
          "sysDescr": "VSP-8404C (8.1.7.0)"
Hello Mig,
thank you for your answer but this query only gives back the Information for the primary node of the stack.
Kind regards
Christoph Schneider
Userlevel 6
Badge +1
Christoph,
I don’t have Summit stack to test it, check withthis if you find something:
  network{devices {
    id
    chassisId
    deviceData {
      addEnableAuthOnAccess
      addSyslogServer
      addToGroup
      addToNacGroup
      addToNetsight
      addToPolicyDomain
      addToSiteArchive
      addToSiteMap
      addTrapServer
      addZtpPlus
      apCount
      archiveId
      assetTag
      bootProm
      chassisId
      chassisMac
      checkRmaConfiguration
      companyName
      connectedIpAddress
      connector
      createDeviceTime
      currentlicenseKey
      defaultSiteId
      defaultSitePath
      details
      deviceASN
      deviceDisplayType
      deviceId
      deviceSitePrecedence
      disconnectPrecedence
      dnsServer
      dnsServer2
      dnsServer3
      dot1qMaxVlanId
      enableCollection
      enforceNeeded
      ezConfigComplete
      ezConfigCompleteError
      ezConfigCompleteOrPending
      ezConfigCompleteWithoutError
      ezConfigConfigFailed
      ezConfigConnect
      ezConfigImageUpgrade
      ezConfigPreReg
      ezConfigReadyToSendConfig
      ezConfigRma
      ezConfigRmaFailed
      ezConfigStaged
      ezConfigState
      ezconfig
      fabricAttachEnable
      fabricAttachRole
      fabricDvrDomainId
      fabricDvrRole
      fabricEnable
      fabricIpV4Shortcuts
      fabricIpV6Shortcuts
      fabricIsisIpSourceAddress
      fabricIsisIpV6SourceAddress
      fabricManualArea
      fabricMulticastEnable
      fabricName
      fabricNickName
      fabricPrimaryBVlan
      fabricSecondaryBVlan
      fabricSystemId
      fabricSystemName
      fabricTopologyType
      fabricType
      family
      firmware
      firstSeenTime
      gateway
      groupId
      hasVendorProfileChanges
      ipAddress
      jsonVendorProfile
      lacp
      lacpLogging
      lastEnforce
      lastEnforceUser
      lastLicenseUpdateTime
      lastSeenTime
      lastUpdate
      lldp
      lldpLogging
      macAddress
      mapId
      mgmtInterface
      mgmtInterfaceOutOfBand
      mgmtInterfaceVlan
      mvrp
      mvrpLogging
      nacApplianceGroup
      nacJsonParameters
      name
      newController
      nickname
      nosId
      note
      ntpServer
      ntpServer2
      ospf
      ospfLogging
      outOfService
      physicalPortCount
      poe
      poeLogging
      policyDomain
      pollGroup
      pollType
      prefix
      preregistrationCreator
      preregistrationTimestamp
      productName
      profileId
      profileName
      regionDomain
      registerSyslogReceiver
      registerTrapReceiver
      replacementSerialNumber
      rmaConfigured
      serialNumber
      siteId
      snmpRetry
      snmpTimeout
      source
      spanningTree
      spanningTreeLogging
      stacking
      stackingLogging
      statisticsCollectionLevel
      status
      subFamily
      syncChangedSnmpField
      syncDesiredFabricDvrLeafModeBoot
      syncDesiredVlansToCurrent
      sysContact
      sysDescr
      sysLocation
      sysName
      sysObjectId
      sysObjectIdName
      timesSeen
      topologyRole
      userData1
      userData2
      userData3
      userData4
      vendor
      vxlan
      vxlanLogging
      wirelessController
      ztpAllowComputeSite
      ztpCLIRecoveryModeOnly
      ztpConfigImport
      ztpDnsSearchSuffix
      ztpDomainName
      ztpLastPollIntervalInMs
      ztpPlusCachedConfigurationHashCode
      ztpPlusCachedFullConfigurationHashCode
      ztpPlusHttpEnabled
      ztpPlusHttpsEnabled
      ztpPlusLldpHoldTime
      ztpPlusRequestConfig
      ztpPlusSnmpEnabled
      ztpPlusSshEnabled
      ztpPlusTelnetEnabled
      ztpScheduledConfigureDate
      ztpScheduledConfigurePending
      ztpScheduledConfigureTime
      ztpScheduledConfigureType
      ztpScheduledDownloadDate
      ztpScheduledDownloadPending
      ztpScheduledDownloadTime
      ztpScheduledDownloadType
      ztpUseDiscoveredMode
Mig
Thanks again. But still only information over the primary node.
Userlevel 6
Badge +1
This is all you’ll be able to get from NBI.
Mig
Userlevel 6
Badge
Hello,
from the XMC point of view, a stack is just one device, no matter how many switches are attached to it. Therefore you won't find any information about stack members anywhere in the XMC (only if you create your own FlexViews and ask MIBs). Correspondingly also not in the NBI.
The only possibility, I see, is to ask the switches directly. You can simply create a script or a workflow that reads the information directly from the switches (stacks) via CLI.
If you need the data externally, you can send it by mail or store it on a file on a network share that is connected to the XMC.
Surely not as nice as query this externally with the NBI. But it works.
Hi Stephan,
can you may help me out? I see an example Python script for executing CLI Commands in the XMC but it seems to be for VLAN configuration. Is there a documentation for how to execute CLI commands via python this? Do you may know how to do it and tell me?
Kind regards
Christoph Schneider
Userlevel 6
Badge
Hello Christoph,
import re
#Send CLI commands
for cmd in cmds:
return False
def main():
commands = []
if result:
if match:
#Start program
main()
Here is the output:
Serial: 8914N-46722
Serial: 8912N-46755
Hope that helps.
Hello Stephan,
yes that helps. Next time I will check on GitHub first.
Thank you.
Kind regards
Christoph Schneider
Userlevel 2
Hey everyone,
To add to this: The information “serials in a Summit Stack” actually is available via NBI on a per-device query basis.
network {
device(ip:"1.2.3.4") {
id
deviceName
deviceData {
macAddress
ipAddress
vendor
family
subFamily
deviceDisplayType
nosId
firmware
entityData {
deviceTopology {
entPhysicalDesc
entPhysicalModelName
entPhysicalName
entPhysicalSerialNum
The serials for each slot will be included as entPhysicalSerialNum.
Please note that this works for exactly the use case stated. Do not rely on correct information for other use cases, there is a long list of caveats with that API call (sorry, cannot disclose, customer-paid work)… And, as usual with the NBI, doing a refresh before firing the query is a good idea.
Reply
