Solved
How do i upgrade ers3650 with extreme mangement center
  • 16 October 2020
  • 1 reply
  • 44 views
some many ers3650 6.2.015 to 6.4.1.007
In EMC    >  configuration/firmeware/>upgrade firmware  > assign image ? format new image
I have 3600_6100_diags.bin and 3600_641007s.img
Thanks  explain to me the procedure with emc
icon
Best answer by Ryan Yacobucci 17 October 2020, 20:18
Hello,
Please check out the following article on how to upgrade using XMC:
https://gtacknowledge.extremenetworks.com/articles/How_To/Upgrading-devices-using-Extreme-Management-Center-XMC-step-by-step/
Make sure you download and transfer the desired firmware and assign it the correct device type when uploaded.
Thanks
-Ryan
View original
1 reply
Userlevel 6
Hello,
Thanks
-Ryan
Reply
