Is there a delay element for XMC workflow
  • 6 November 2018
  • 0 replies
  • 981 views
Userlevel 6
Badge
Hello,
is there a delay element available in XMC workflows?
I know there is a boundary timer, but if I understand correctly this element is useful in case of an activity is not completed correctly and this timer uses an alternative path.
But I need an element within the path. I will pause the workflow for a given time (example 30 seconds) and then go forward in the same path! I do not want to observe the outcome of an activity.
I know I can create a timer with python but I hope there is a ready to run solution in workflows 😉.-
Best regards
Stephan
Be the first to reply!
Reply
