Question
pelase help me..
  • 14 October 2020
  • 11 replies
  • 131 views
When importing DHCP, the existing + additional list was shown.
Currently, only the additions are visible.
I think my colleague touched the eac role and rule..
Is there any way to solve it?
Help the experts ~
Controel > End System   seems to be classified.
Userlevel 7
  • check the display filters. The icon at the top, left to the magnifier glass.
  • try another browser
  • refresh the web browser
  • clear browser cache (in the hamburger menu top right)
Userlevel 6
Badge +1
A mentioned by Zdenek check this:
The same is true for other PCs.
no filter
My colleague.
I touched the policies on the Controle tab.
It doesn't seem to come out after that.
What should I check?
Userlevel 7
Do you have the XML file you imported?
I can try to replicate it.
Userlevel 6
Badge +1
Maybe the switch to advanced in the policy mappings:
Hi Zdenek Pala
What xml file are you talking about?
Hi Miguel-Angel RODRIGUEZ-GARCIA
What do you mean?
Userlevel 7
There is a screenshot In the original post. There are custom dhcp fingerprints. I expect you imported those fingerprints from XML file.
Userlevel 6
Badge +1
Hyshin,
you mention that somebody touched the Policies on the control tab.
When you go to this tab, there is a switch button between advanced and basic tab used to limit the info on the screen.
Mig
relplay Zdenek Pala
dhcp file not reload…
only import xml
I don't know what you are talking about.
Why do you refresh..?
My thoughts don't seem to be a problem to be solved by refreshing.
Userlevel 4
Badge
you should have a look, what he has written and not only look at the screenshot.
His mention was to maybe switch the view. He has not written to use “refresh button”.
Reply
