What are my options for EXOS Network Management Automation
Before I just go off and implement a solution based on the EXOS telnet command interface, I am looking to the community for advice on whether this is the "best" switch interface to use for this purpose, what the alternatives and pros and cons of each are.
I am only aware of the SNMP alternative. I have not considered it very seriously yet because we are using these switches for, among other things, AVB media transport and monitoring, and the last I checked, the MIB does not yet support AVB-related interfaces, e.g. MSRP/MVRP and stream status.
Thanks for your consideration,
Tim
If I understand you correct then you still only need the ability to configure the XOS switches.
As you point out correct you can use the CLI or SNMP.
In my opinion the CLI is the better way:
- Your have a well formed documentation
- Easy access to all settings
- Read/Write ability
- Feedback in case of an failure
- write many values directly, but not all
- Have the difficulty do find the correct values or setting
- No feedback what's going wrong in case of an failure
- No special documentation
Do you know XMC?
With the Management solution XMC from Extreme you can read out a lot of information's from the devices.
In combination with NAC even the mentioned information's like which device is on which port (IP, MAC, ...). Furthermore there is a script engine to use python scripts directly in management system.
You can trigger the scripts on different ways (manual, scheduled or within an workflow (e. consisting of different event, alarm or scripts).
There are a lot of variables which you can use directly for the communication with the switches. Therefore you have not to think about how the communications work
In addition there is a GraphQL-API to receive a lot of information's from the XOS devices (via the XMC management)
and a REST-API for receiving and writing data to XMC.
I know this is not comprehensive answer. But I am not sure if you knowing these different way to communicate directly and indirectly with XOS.
Additionally you have the ability to execute Python scripts directly on the XOS switches maybe this is useful for your need.
Best regards
Stephan
Do you know XMC?
Best regards
Stephan
Do you know XMC?
Best regards
Stephan
@James A, I would say the same about Ansible. I am familiar with Ansible for machine configuration management, and would be very interested in learning more about who is implementing the Ansible support and how mature it is.
Do you know XMC?
Best regards
Stephan
https://github.com/extremenetworks/ansible-extreme#exos AND
https://docs.ansible.com/ansible/devel/modules/exos_command_module.html
..although it looks like there are several people working on new modules now (exos_config and exos_facts) which have outstanding pull requests to the core ansible team. This is great, but not enough for my team at the moment, so I'm going to eliminate Ansible approach for now.
So I'm having trouble making sense of XMC - I assume you're referring to Extreme Management Center:
https://emc.extremenetworks.com/content/home.htm
This appears to be a Windows/Linux desktop application that can be used to manage exos switches. Not sure this is what Stephan meant.
So, for the time being, I'm going to stick with the CLI via telnet, but please send more info if you have experience with remote automated programmatic control of EXOS switches! Thanks!
Do you know XMC?
Best regards
Stephan
Do you know XMC?
Best regards
Stephan
Do you know XMC?
Best regards
Stephan
The latter link (like your https://api.extremenetworks.com link) pretty much summarizes what I'm looking for: the currently available options for remote, programmatic control and management of EXOS switches. XMC is not there but that's appropriate since it's not really intended for remote applications integrating with switches. (And if it were intended for this, I can't imagine a scenario in which someone would choose to use XMC over one of the supported APIs.)
I will follow up soon on that thread you linked to to see if any of the APIs have added support for introspecting AVB, MSRP, SVRP, GPTP info in the last 3 years. As you saw in your search, I'm not finding anything specific about these interfaces, and I think the expectation is that, e.g. using JSONRPC, you're supposed to just use jsonrpc.cli() to invoke the remote "show msrp streams" command and then your remote app gets the response back as a nice tidy json structure.
Cheers, and thanks!
Do you know XMC?
Best regards
Stephan
Do you know XMC?
Best regards
Stephan
As for XMC, yes this is Extreme Management Center. With recent releases (8.1+) you have Python scripting integrated. That's nice if you have older switches that cannot upgrade to 21.1+ (for jsonrpc) or some other vendor switches. XMC would manage for you access to the devices, just handle in your code the type of platform (XMC provides variable for that too). With the coming 8.2 version, Workflows will be also provided in XMC. So you'll be able to have several scripts running with conditional gateways, alarm trigerring, etc.
Do you know XMC?
Best regards
Stephan
I'm curious about your internal work (the demo-tool you mention) to generalize the pushing configuration to switches via jsonrpc interface. How doess your demo tool model configuration changes? Are they represented by just a sequence of CLI commands?
Right now, we are only toggling ports from our test automation, however we will shortly be needing to implement more complicated dynamic configuration changes, which will happen during the setup phase of a particular test suite. Is it appropriate in this case to model these as a simple sequence of CLI commands that get executed? Is there a "reset switch" command that you would you recommend we prepend to the command sequence to ensure the same starting point each time?
We are using the OOB Mgmt port, BTW, to ensure we maintain connectivity during these operations.
Do you know XMC?
Best regards
Stephan
Do you know XMC?
Best regards
Stephan
So you create your own task files and run them with the tool (shell or web). The web front-end was also able to create the json task file.
The tool tries to find if an error occurred, but that's a tricky part, I need to parse the output. I think I also have an option to stop on an error, or not.
Do you know XMC?
Best regards
Stephan
Wow, putting forward exos proposals is already worth praising. Cool, but I don't think you need to think about alternatives. By the way guys thank you so much for the information, it was very interesting to read, I learned a lot of new things
I want to add! This automated system is installed in many similar cases and I have it in a small business as well. I did not know that with its help, you can use it to see which ports of the switch are connected to which devices under test . However, the system broke after 2 months of operation, but my colleagues quickly recommended me https://www.automationstop.com/ and I easily repaired our system. Now I'm thinking about getting the same system to my home to move some of the work home and save some time. Such a system is not particularly expensive and I think that I can afford another similar one.
Reply
Enter your username or e-mail address. We'll send you an e-mail with instructions to reset your password.
