Solved
XMC Wireless Management Controller Name
  • 8 October 2020
  • 7 replies
  • 77 views
Userlevel 4
Hello,
in XMC Wireless Manager IdentiFi Controllers are displayed with their IP-Address and XCC Appliances are displayed as “controller”.
On the controllers itself they have a proper name configured.
This makes it hard to distinguish.
Any way to change this? So that at least the XCC Appliances are displayed with their IP-Address? Better would be to have the Name displayed.
XMC version is 8.5.0.
Best regards
Stefan
icon
Best answer by Stefan K. 9 October 2020, 09:56
Hi Mig,
this is the same for me now. I think the restart fixed this. Well, better than nothing. :)
Thank you!
Stefan
View original
Userlevel 6
Badge +1
Stefan,
Do a right click on it and select Configure
Go to the tab Device Annotation and delete the nickname.
Rediscover the device and it should show the snmp name.
Mig
Userlevel 4
Hi Mig,
thank for the quick reply. A nickname was already set for all the  controllers, but I set it again and did a rediscover. XCCs are now displayed with their Nickname, IdentiFi still with their IP-Address. Strange… Any idea? Otherwise this would be okay for me that way.
Best regards
Stefan
Userlevel 6
Badge +1
Stefan,
You have to delete the nickname and rediscover.
Let me know
Mig
Userlevel 4
Aah, yes, you’re right… Reading is hard. :D
I just did that: Deleted the Nickname and then did a rediscover. Network → Devices now shows the System Name for the controllers. So far so good, but under Wireless → Controllers it now still shows IP-Addresses for IdentiFi and “controller” for XCC.
Well… Seems like setting a nickname manually for these devices at least works for XCC. Not using a nickname at all will result in “controller” being shown.
Userlevel 4
I did an Upgrade to 8.5.1 - now the XCCs are also listed with their IP-Address and not with “controller”. Not sure if the update or the server restart during the update is responsible for this.
Userlevel 6
Badge +1
Stefan
I’m running 8.5.0 and XCC are listed with their IPs while in devices I see the snmp discovered name.
Mig
Userlevel 4
Hi Mig,
Thank you!
Stefan
Reply
