"404 - Not Found" on xmc VM
  • Question
  • Updated 1 month ago
  • Answered
I have read a number of KBs on this, but they don't seem to apply to us a we don't have the same paths.
This article: https://gtacknowledge.extremenetworks.com/articles/Solution/Unable-to-access-Extreme-Management-with... says to edit "/Install_path/NetSight/wildfly/standalone/configuration/emc.xml" except we don't have a "widlfy" subdirectory in our install.  We are running 8.1.2.59 whch we downloaded as a .ova file and deployed from that
Photo of Stephen Stormont
Stephen Stormont
  • 792 Points 500 badge 2x thumb
Posted 2 months ago
Photo of Bharathiraja, Suresh
Bharathiraja, Suresh, Employee
  • 3,444 Points 3k badge 2x thumb
Hi Stephen,
Can you confirm two things here
1) Extreme management center is not working and you are getting 404 error with similar server.log as mentioned in KB ?
2) This issue occurred once after upgrade  ?
Thanks,
Suresh.B
Stephen Stormont
We did not perform any upgrades; we deployed 8.1.2.59 directly from the ova file and we will randomly get the 404 error.  the only way to resolve it is to restart the XMC VM.
All articles that I have read regarding 404 errors all mention editing files that do not exist in our installation.
Photo of Kurt Semba
Kurt Semba, Employee
  • 1,306 Points 1k badge 2x thumb
Starting with XMC v8.0 we are using wildfly as the application server.
Please paste the content of this folder from your XMC: /usr/local/Extreme_Networks/NetSight
Stephen Stormont
Ok, in "/usr/local/Extreme_Networks/NetSight/wildfly/standalone/configuration" I do have the emc.xml file, however it appears to already have a deployment-timeout section set so I guess that isn't the fix for the "404 - Not Found" error in my case.
        <deployment-scanner path="deployments" relative-to="jboss.server.base.dir" scan-interval="60000" deployment-timeout="7200" auto-deploy-zipped="false" auto-dep    loy-exploded="false" runtime-failure-causes-rollback="${jboss.deployment.scanner.rollback.on.failure:false}"/>
Photo of Kurt Semba
How much RAM does your VM have and how much RAM did you assign to the wildfly server (check file: /usr/local/Extreme_Networks/NetSight/services/nsserver.cfg)?
Version 8 has new RAM requirements: https://gtacknowledge.extremenetworks.com/pkb_mobile#article/Solution/kA0340000000SZqCAM/s
Stephen Stormont
We didn't make any changes to the settings after the .ova was deployed (thought everything was supposed to be configured as per recommendations via that method).
The VM has 32 GB of RAM.
The nsserver.cfg file shows the follwoing:
 -Xms8g -Xmx8g -XX:HeapDumpPath=../../nsdump.hprof -XX:+HeapDumpOnOutOfMemoryError -XX:MetaspaceSize=128m
I will change that to match the suggestions on the page that you linked for a Medium system and see how things go.
Stephen Stormont
Just had this happen again and the server is currently in a state showing the "404 - Not Found".  What can I look at to see what may have caused it to go down again?
Stephen Stormont
Just found out that XMC has been down since 5/26/18 until I rebooted the server today.  Any other ideas into what we can look into as a path for resolution?  It is definitely disconcerting to not have devices backups for those nights and we don't know what would happen if this server is actually brought live using NAC and the same thing happens again.
Stephen Stormont
Apparently this was a known bug that was fixed with the release of 8.1.3.65.
