(EOS) Installing Previously-Configured Systems in a Stack
  • Question
  • Updated 3 years ago
  • Answered
I was tasked to replace a stack three Enterasys C2's with three C5's. That part went as expected and worked great. However, there is a fourth switch in the rack. It is also a C5 running the same firmware as the stack of three. I know I can bring in the fourth but I am not sure what will happen to the configuration on the fourth.
What I hope:
Since the VLAN's are the same, ports numbered ge1.1 will suddenly become ge.4.1. My VLAN's
set vlan egress 10 ge.1.1-10 tagged
Will become
set vlan egress 10 ge.4.1-10 tagged
and so forth
Pipe dream or miracle?
Photo of rhaviland
rhaviland
  • 244 Points 100 badge 2x thumb
Posted 3 years ago
Photo of Andre K.
Andre K.
  • 356 Points 250 badge 2x thumb
The port configuration on the fourth unit will be blank/default when it becomes a stack member. Once you add the unit to the stack, you will have to reconfigure the ports.
For preparing the plain untagged VLAN config you could do this:
- issue "show config port" on the single unit
- copy output to a text editor
- replace "ge.1." with "ge.4."
- add unit to stack
- copy commands from text editor to CLI
Be aware that there might be other Port-based settings that you might need to configure (e.g. tagged vlan egress, LLDP, policy, authentication).
