[S-Series] [VSB] HAU Incomptible with 08.11.04.0006
  • 2
  • Problem
  • Updated 2 weeks ago
Hello Community,
I have an Chassis based S-Series configured as an VSB, running EOS 08.11.04.0006.
Primary due to an SNMP problem (Switch doesnt respond reliable to SNMP querys) I would like to do an HAU upgrade to 08.62.04.0002, but the HAU Key told me "(HAU incompatible)".
Is it possible to update in multiple "HAU compatible" steps, to prevent a full reboot of both cassis?
Thanks!
Jan
Photo of Jan Steinbach
Jan Steinbach
  • 1,192 Points 1k badge 2x thumb
Posted 2 weeks ago
  • 2
Photo of James A
James A, Embassador
  • 7,338 Points 5k badge 2x thumb
HAU upgrades are only possible when the HAU key (listed in each version's release notes and the firmware on the switch with "dir") matches, and it's a hard break, there are no overlapping versions that have two HAU keys. https://community.extremenetworks.com/extreme/topics/7100_s_n_series_high_availability_upgrade_hau_v... has an older list, but it looks like you're out of luck.
