"Unable to resolve IP address using SNMP, NetBIOS or DHCP" and "MAC to IP Resolution Failed" errors
  • Problem
  • Updated 4 months ago
  • Solved
Hello, everybody,
I've noticed a lof of error messages in Netsight > Control > Endpoints like:
1) Unable to resolve IP address using SNMP, NetBIOS or DHCP
2) MAC to IP Resolution Failed
I suppose that there is a connection between two messages. How can I solve the issue?
Many thanks in advance,
Ilya
Photo of Ilya Semenov
Ilya Semenov
  • 4,154 Points 4k badge 2x thumb
Posted 4 months ago
Photo of Mike Thomas
Mike Thomas, Employee - GTAC - NMS
  • 7,404 Points 5k badge 2x thumb
This is a good place to start.
https://gtacknowledge.extremenetworks.com/articles/How_To/NAC-Troubleshooting-Tips-Debug-Methodology...
There are also several other more specific artlcles on the knowledgebase regarding IP resolution.
Ilya Semenov
  • 3,964 Points 3k badge 2x thumb
Thanks, Thomas! I'll start the case in GTAC. Could you please share some links to the articles you've mentioned?)
Photo of Ronald Dvorak
Ronald Dvorak, Embassador
  • 44,332 Points 20k badge 2x thumb
From the screenshot I'd see that all the clients get the "default catchall" rule - what is the policy behind it > it assume if the login-LAT-port is set to 0 (=unauthenticated) that no DHCP is passing the port = no information in ExtremeControl.
Ilya Semenov
Hi, Ronald,
actually, I didn't get your idea... What shoul I correct to fix the problem?
Thank you!
