10.41.10 - dashboard, low link speed shows wrong value
  • 2
  • Problem
  • Updated 3 weeks ago
  • Solved
I've just upgraded a customer controller from 10.41.05 to 10.41.10 and now the dashboard show 213 APs with low link speed = all APs.
I've checked one switch with about 10 APs and the "show port no" result is that all the AP ports are actual speed/duplex of 1000/full.
Tried a reboot of 10 APs but no change.
If you click on the low link speed counter the pop-up list only 3 APs - not sure whether that is the max that is shown in this window.
I'd see the same result on my lab controller - even there are only 8 out of 12 with low link speed - I know that is also not correct.
Is that a known issue !?
-Ron
Photo of Ronald Dvorak
Ronald Dvorak, Embassador
  • 51,226 Points 50k badge 2x thumb
Posted 3 weeks ago
  • 2
Photo of Craig Guilmette
Craig Guilmette, Employee
  • 2,984 Points 2k badge 2x thumb
Hello Ron
Yes it is a known issue and fixed already by Engineering and will be in the 10.41.11 release.
Thanks Craig..... so more overtime to upgrade to 10.41.11 :-)
KR,
Ron
https://gtacknowledge.extremenetworks.com/articles/Solution/10-41-10-code-clicking-low-link-speed-li...
This doc needs to be altered to list low link when there really isn't as well but at 1 time we thought it was 2 different problems and wrote 2 docs.
Any ETA on the release date for 10.41.11 ?
Thanks,
Ron
Photo of Gareth Mitchell
Gareth Mitchell, Extreme Escalation Support Engineer
  • 5,994 Points 5k badge 2x thumb
Ron
Provisional release date is 14/11/18, although this maybe subject to change.
-Gareth
Thanks Gareth
