10931 PSU is compatible with x460g2?
  • Question
  • Updated 2 years ago
  • Answered
I have a switch x460g2 48p without psu and have a 10931 psu docs say that 10931works with x460 but doesnt specify generation. Is 10931 compatible?
Thank you in advance.
Photo of juan romero
juan romero
  • 400 Points 250 badge 2x thumb
Posted 2 years ago
Photo of Andrew Imam
Andrew Imam, Alum
  • 1,026 Points 1k badge 2x thumb
Hi Juan,
Since you are referring to the X460-G2-48p (2nd Gen X460 with POE capabilities), according to page 15 of the X460-G2 Data Sheet, you have a choice between the following:
1) Summit 1100W AC PSU:  Choose a PSU with a matching airflow to the switch: either part# 10941 (FB --> Front-to-Back airflow) or part# 10942 (BF --> Back-to-Front airflow).
2) Summit 715W AC PSU: Choose a PSU with a matching airflow to the switch: either part# 10951 (FB --> Front-to-Back airflow) or part# 10952 (BF --> Back-to-Front airflow).
The Summit 1100W AC PSU can provide 850 watts of POE-plus power budget per one power supply and the Summit 715W AC PSU can provide 500 watts of POE-plus power budget per one power supply. If a higher power budget is required, two of the same type of power supply (two Summit 1100W AC PSUs or two Summit 715W AC PSUs can be installed in either the X460-G2-48p-10GE4 or X460-G2-48p-GE4 switch, based on the model you have.
You can click on the link below to access the X460-G2 Data Sheet on our web site for more information:
http://learn.extremenetworks.com/rs/extreme/images/Summit-X460-G2-DS.pdf
Based on you POE power budget requirements, please refer to page 7 in the X460-G2 Data Sheet to get more information regarding the POE power budget allocation which will help you determine which PSU(s) would better suit your current and future POE power needs.
Please let us know if you have any questions.
Thank you.
Best regards,
Andrew
