24 port 1g copper & 4 port 10g copper
Saravanamurthy_
Contributor
Which extreme switch model is match for 24 port 1g copper & 4 port 10g copper. or else what is an other option for this requirements?
2 REPLIES 2
Drew_C
Valued Contributor III
The X460-G2-24t-10GE4 has 24 1G copper ports, 8 1G SFP ports, and 4 10G SFP+ ports. To get 10G copper, you'll only be able to get 2 10G ports with the X460-G2 VIM-2t.
https://www.extremenetworks.com/product/x460-g2-series/
If you can handle fewer 1G ports, the X620 models may be an option: https://www.extremenetworks.com/product/x620/
Nick_Yakimenko
New Contributor II
it may be X480 with vim2-10g-4x module
https://www.cnet.com/products/extreme-networks-summit-x480-vim2-10g4x-expansion-module-4-ports/specs...
But you probably will not find any 10g copper ports in any Extreme switches
