3705i in Autonomous mode
Declan_Liddy
Hi I will be performing site surveys using a Enterasys 3705i access point is there a way of making it autonomous, is there a model that can be made autonomous
Thanks for the replies
10 REPLIES 10
Declan_Liddy
Will it let me set the AP up as Autonomous and have both radios on
Thanks
Tomasz_Lubas
New Contributor III
As i remember if you use evaluation version till it expires AP's can join but only 1 radio can be on.
Declan_Liddy
If I get a v2110 vm spun up will it let the Ap join, would there be license needed or is there a trial period
Thanks
