3710i Extreme AP client connection
  • Problem
  • Updated 3 years ago
  • Solved
I have two 3710 IdentiFi AP's in a conference room. The controller is a C25.There are also wireless mics, projector and Apple TV set up. When a wireless client enters the room they are unable to connect. If there are 25 devices in the room at the most 5 will connect. I have reset the AP's and the clients, but still no go. Has anyone experienced this or know of a solution. IN the controller they are set up like the 3610's and the 3825's I have.
Thank you
Photo of Michael Ezell
Michael Ezell
  • 180 Points 100 badge 2x thumb
Posted 3 years ago
Photo of Doug Hyde
Doug Hyde, Technical Support Manager
  • 20,394 Points 20k badge 2x thumb
Any load group settings?
Photo of Doug Hyde
Also are you using bridge at controller or ap? If B@AP, what type of switch are they attaching to? Any policy or mac locking rules on the switch?
Photo of Tony
Tony
  • 550 Points 500 badge 2x thumb
Is the AP3710 active in both frequency bands (2.4 and 5 GHz)?
Michael Ezell
I do not have any load group settings. They are bridge at the AP. They are connected to a C3 switch. No policy or mac locking rules. Yes I do believe that they are active in both bands.
Photo of Doug Hyde
I would suggest contacting the GTAC so we can get a trace of the ap's eth0 port during the time of the issue.
Michael Ezell
OK. Thank you. That was my next route, but just wanted to see if anyone else had seen it and maybe had an easy fix.
