3805 Ethernet Speed
3805 Ethernet Speed
Jeremy_Gilbrech
The data sheet for the 3805 access point shows that the ethernet port supports up to 1000 Mbps but on our c5210 I only see options to configure it up to 100 Mbps. Am I missing something somewhere?
3 REPLIES 3
Ronald_Dvorak
Honored Contributor
You'd get 1G only if the port is set to Auto = autonegotiation is enabled.
If you have autonegotiation also enabled on the switch port you should be able to get a 1G link between switch and AP.
There is no static setting for 1G in the GUI.
fec28c82d2f44ab3910db4eccb5688d7_RackMultipart20181019-40363-1qwfbrm-AP38xx_static_config_inline.png
Umut_Aydin
Or the AP was set to 100Mbit/s in the previous config?
SSH to AP and set it to factory default.
#cset factory default
Doug
It could be a bad cable or PoE adapter.
Doug Hyde
Director, Technical Support / Extreme Networks
