3825i console access issue
  • Problem
  • Updated 10 months ago
  • Not a Problem
Hello, everybody,
could you please tell me how can I manage 3825 over console.
I've connected to it using 115200bps, I can see it's startup log output, but can't login. It does not accept keys input.
Is it possible?
Many thanks in advance,
Ilya
Photo of Ilya Semenov
Ilya Semenov
  • 4,610 Points 4k badge 2x thumb
Posted 10 months ago
Photo of Doug Hyde
Doug Hyde, Technical Support Manager
  • 20,502 Points 20k badge 2x thumb
It should boot to a prompt where it would accept input from the console. I would try a different cable. What are you trying to do in the shell? In the 10.41 code we added the remote shell tab to the ap properties:
https://gtacknowledge.extremenetworks.com/articles/How_To/How-to-SSH-or-open-the-AP-s-Remote-Console...
Photo of Alexandr P
Alexandr P, Embassador
  • 12,192 Points 10k badge 2x thumb
Hello, Ilya!
Did you check that console cable with right pins and all pins is connected?
https://gtacknowledge.extremenetworks.com/articles/Solution/WS-AP3825i-booting-to-boot-mode-when-a-l...
May be Tx signal don't received by AP from lap-top?
Thank you!
Ilya Semenov
I've used CISCO cable. What a fun thing? I can see console output from AP, but can't input commands...
Photo of Doug Hyde
We had a similar issue so we stopped using those and started using a USB one https://www.tripplite.com/usb-rj45-cisco-serial-rollover-cable-usb-type-a-rj45-6-ft-microsoft-surfac...
