3965i/e PSE Out (LAN2)
  • Question
  • Updated 7 months ago
  • Answered
Hi Community
Has anyone played with the POE out port on the 3965 series AP's??
I do not seem to be getting any power out on the send port to power a normal 802.11af IP Camera.
I seem to recall a year or two ago that this feature was going to be made available in a future software release.
Has this been done??
Photo of Andre Brits Kannemeyer
  • 5,160 Points 5k badge 2x thumb
Posted 10 months ago
Photo of Sam
Sam, Employee
  • 1,858 Points 1k badge 2x thumb
Hi Andre,
What version of firmware are you using and how much power is the AP able to draw?
As per the Installation guide:
Power consumption < 22W (Max.) when operating as AP only
< 55W (Max.) when operating as AP and providing power to a second device
Also is the LAN 2 port enabled?
Whats the power requirements of the camera?
- Sam
Hi Sam
We are running version 10.41.x.x (Latest Firmware)
The AP is the only connected device on a POE+ (HP/Aruba 2530)
How do you enable or disable the LAN port?
Photo of Ostrovsky, Yury
Ostrovsky, Yury, Employee
  • 3,050 Points 3k badge 2x thumb
As I know , the PoE out (on the second port) it not yet supported on 3965 AP . Currently only 3912i  AP support PoE daisy chain  .
(Edited)
Yes it works fine on the 3912i, but not the 3965i/e
Can we confirm this as a fact??
(Edited)
Photo of Doug Hyde
Doug Hyde, Technical Support Manager
  • 20,502 Points 20k badge 2x thumb
