4 channel plan on 2.4 Ghz.
  • Question
  • Updated 1 year ago
  • Answered
4 channels plan on 2.4Ghz doesn't work on APs 3825i+3805i with Controllers C5210.
We would like to try a 4 channels plan on 2.4 Ghz. We can put this configuration on the APs but you can not see it on the APs. Only 3 channels (1-7-13) in use.
Something wrong in my configuration??
Thanks in advance.
Photo of Rey Juan Carlos University [communications]
Posted 1 year ago
Photo of Umut Aydin
Umut Aydin, Escalation Support Engineer
  • 2,300 Points 2k badge 2x thumb
Hi Rey,
the AP will take the new channels if you request new channel (auto) or reboot the AP after changing.
Can you test this?
If already done we need more info like fw version or a screenshot would also help.
Does it work in other AP's or on 5Ghz with custom channel plan?
Regards
Umut Aydin
Hi Rey,
We have channels on auto and we rebooted the APs after changing. We don't try it on 5 Ghz.
Fw version: 10.21.04.0005
hwc - C5210
APs mix of 3935/3965/3825/3805
(Edited)
Photo of Ronald Dvorak
Ronald Dvorak, Embassador
  • 51,186 Points 50k badge 2x thumb
You've to set/apply channel auto again for the channel plan to take affect.
I don't think that ACS will re-run if you reboot the AP.
(Edited)
Thanks Ronald, that was the problem.
We had to select the radio in auto again.
Thanks a lot.
Photo of Umut Aydin
Could you please check if you have Dynamic Channel Selection enabled under the advanced button?
