404 - Not Found
  • Problem
  • Updated 7 months ago
  • Solved
Hi there,
I'm using VX9000(5.9.1.2-006R) with 54 AP7532 adopted with it.
While checking from AP configuration on management-policy default http and https server both are enabled.
But while trying to connect from web UI I'm getting error of 404- Not Found on both https and http.
Photo of Vimalraj Veerabathiran
  • 448 Points 250 badge 2x thumb
  • Indifferent
Posted 7 months ago
Photo of Robert Zarzycki
Robert Zarzycki, Employee
  • 4,826 Points 4k badge 2x thumb
Thanks for the update.
How to check from AP side it is loaded with LEAN image or full image .?
The controller by default uses the lean image to upgrade the APs during adoption.
Photo of Daniel Mejia
Daniel Mejia, Employee
  • 1,056 Points 1k badge 2x thumb
Hi Vimalraj,
As Rob stated, Adopted APs are provisioned with a lean image upgrade when adopted and managed by a controller. Lean images do not provide GUI access since controller management is assumed.
Photo of Christopher Frazee
Christopher Frazee, Employee
  • 2,026 Points 2k badge 2x thumb
There is no method on the controller to determine if the AP images are LEAN or not. WiNG 5 wireless controller starting using LEAN images for APs starting v5.8.
Photo of Bin
Bin, Employee
  • 5,372 Points 5k badge 2x thumb
Thanks Bin.
