A little ACL help
  • Question
  • Updated 3 months ago
  • Answered
  • (Edited)
I'm developing an ACL to allow guest use of certian resources on my network.  In the end, the guest network will be its own subnet.  So, I want to apply this ACL at the VLAN level.  I've got the ACL working at the port level, but when I apply it to the VLAN nothing works...
Where might I be messing this up?
entry allowswitchcom  {
    if  {
source-address 10.0.99.200/32;
        }  then  {
    permit;}
entry allowswitchcom2  {
    if  {
        source-address 10.0.99.254/32;
        }  then  {
    permit;}
entry denyswitch  {
    if  {
destination-address 10.0.99.200/32;
source-address 10.0.99.0/24;
}  then  {
    deny;}
entry denyswitch2  {
    if {
        destination-address 10.0.99.254/32;
        }  then  {
            deny;}
entry denylocalssh  {
    if  {
        protocol tcp;
        destination-port 22;
        }  then  {
            deny;}
entry sshmgmt  {
    if  {
        destination-address 10.0.99.0/24;
        protocol tcp;
        }  then  {
            deny;}
entry allowmakerlab  {
    if  {
}  then  {
    permit;}
entry allowdhcp  {
    if  {
    source-address 0.0.0.0/0;
protocol udp;
destination-port 67-68;
}  then  {
    permit;}
entry allowdns  {
    if  {
protocol udp;
destination-port 53;
}  then  {
    permit;}
entry allowntp  {
    if  {
protocol udp;
destination-port 123;
}  then  {
    permit;}
entry allowvncmgmt  {
    if  {
        protocol tcp;
source-port 5900-5910;
        }  then {
    permit;}
entry allowwinlogon  {
    if  {
protocol tcp;
destination-port > 1024;
destination-address 10.0.66.220/32;
}  then  {
    permit;}
#entry allowprint515  {
#    if  {
#     destination-address *printerIP/32;
# protocol tcp;
# destination-port 515;
# }  then {
#     permit;}
#entry allowprint631  {
#    if  {
# protocol tcp;
# destination-port 631;
# }  then {
#     permit;}
#entry allowprint9100  {
#    if  {
# protocol tcp;
# destination-port 9100;
# }  then {
#     permit;}
entry denyHTTPinternal10 {
    if  {
    destination-address 10.0.0.0/8;
protocol tcp;
destination-port 80;
}  then  {
    deny;}
entry denyHTTPinternal192 {
    if  {
    destination-address 192.168.0.0/16;
protocol tcp;
}  then  {
    deny;}
entry denyHTTPinternal172 {
    if  {
    destination-address 172.16.0.0/12;
protocol tcp;
}  then  {
    deny;}
entry denyHTTPsinternal10 {
    if  {
protocol tcp;
destination-port 443;
}  then  {
    deny;}
entry denyHTTPsinternal192 {
    if  {
protocol tcp;
}  then  {
    deny;}
entry denyHTTPsinternal172 {
    if  {
protocol tcp;
}  then  {
    deny;}
entry allowhttpinternet  {
    if  {
    protocol tcp;
}  then  {
    permit;}
entry allowhttpsinternet  {
    if  {
    protocol tcp;
}  then  {
    permit;}
entry denyall  {
    if  {
        }  then  {
            deny;}
Photo of Terren Crider
Terren Crider
  • 1,364 Points 1k badge 2x thumb
  • braindead
Posted 3 months ago
Terren Crider
Tried to make some code tags... but that didn't work for me, either.
Photo of George Smith
George Smith, Employee
  • 110 Points 100 badge 2x thumb
Maybe in the
entry denyswitch  {
    if  {
}  then  {
    d eny;}
There is a space in the “deny” that should not be there?
Terren Crider
  • 1,362 Points 1k badge 2x thumb
I don't have any undue spaces in the .pol file itself.
Terren Crider
Is it possible to apply an ACL to a VLAN but exclude one port?
Edit:  My thought here is that the VLAN in question in my lab setup is also on the uplink port of the switch.
(Edited)
Photo of tknv
tknv, Employee
  • 134 Points 100 badge 2x thumb
Hi Terren,
I am not certain problems, but if early permit condition contain deny condition and earlier than the deny condition, that would be permitted. Thus deny first (better all deny condition) more safer.
If yet problem, please let us share exactly which packet should be deny/permit with us.
Terren Crider
I have it working now.  I'm still not sure what was getting blocked, but I added an entry to allow bidirectional traffic to my VLAN.
entry allowbidirectional  {
    if  {
        }  then  {
            permit;}
This was added as the second to last entry, right above the denyall rule.
Edit:  I also changed the order of some things.  Like allowing DNS, DHCP, NTP at the top rather than in the middle.
(Edited)
Photo of tknv
tknv, Employee
Probably earlier entry blocked it. Can you share whole ACL .pol?
Photo of Grosjean, Stephane
Grosjean, Stephane, Employee
  • 12,302 Points 10k badge 2x thumb
not sure if it applied here, but the difference when using VLAN for ACL is that it applies only to traffic entering the VLAN (not exiting it).
Terren Crider
Here's the current working ACL.  Without the second to last entry "allowbidirectional" it does not work.
entry allowDHCP  {
    if  {
pr otocol udp;
}  then  {
    permit;}
entry allowDNS {
    if  {
protocol udp;
}  then  {
    permit;}
entry allowNTP  {
    if  {
protocol udp;
}  then  {
    permit;}
entry allowVNCmgmt  {
    if  {
        protocol tcp;
        }  then  {
permit;}
entry denylocalSSH  {
    if  {
        protocol tcp;
        }  then  {
            deny;}
entry SSHmgmt  {
    if  {
        protocol tcp;
        }  then  {
            permit;}
entry allowNetSightin  {
    if  {
        source-address 10.0.200.216/32;
        }  then  {
            permit;}
entry allowNetSightout  {
    if  {
destination-address 10.0.200.216/32;
        }  then  {
            permit;}
    if  {
        }  then  {
permit;}
    if  {
        }  then  {
permit;}
entry denyHTTPswitch  {
    if  {
protocol tcp;
}  then  {
deny;}
entry denyHTTPswitch2  {
    if {
protocol tcp;
}  then  {
            deny;}
    if  {
}  then  {
    permit;}
entry denyICMP  {
    if  {
        protocol icmp;
        }  then  {
            deny;}
#entry allowwinlogon  {
#    if  {
#     source-address 10.0.99.0/24;
# protocol tcp;
# destination-port > 1024;
# destination-address 10.0.66.220/32;
# }  then  {
#     permit;}
#    if  {
# protocol tcp;
# }  then {
#     permit;}
#    if  {
# protocol tcp;
# }  then {
#     permit;}
#    if  {
# protocol tcp;
# }  then {
#     permit;}
    if  {
protocol tcp;
}  then  {
    deny;}
    if  {
protocol tcp;
}  then  {
    deny;}
    if  {
protocol tcp;
}  then  {
    deny;}
entry denyHTTPSinternal10 {
    if  {
protocol tcp;
}  then  {
    deny;}
entry denyHTTPSinternal192 {
    if  {
protocol tcp;
}  then  {
    deny;}
entry denyHTTPSinternal172 {
    if  {
protocol tcp;
}  then  {
    deny;}
entry allowHTTPinternet  {
    if  {
    protocol tcp;
}  then  {
    permit;}
entry allowHTTPSinternet  {
    if  {
    protocol tcp;
}  then  {
    permit;}
    if  {
        }  then  {
            permit;}
entry denyall  {
    if  {
       }  then  {
            deny;}
Photo of tknv
tknv, Employee
Thank you very much. I think a packet (to/from 10.0.0.0/8) is not match below should be permit.
	if  {
		protocol tcp;
	}  then  {
		deny;}
	if  {
		protocol tcp;
	}  then  {
		deny;}
	if {
		protocol tcp;
	}  then  {
		deny;}
entry denyICMP  {
	if  {
		protocol icmp;
	}  then  {
		deny;}
	if  {
		protocol tcp;
	}  then  {
		deny;}
	if  {
		protocol tcp;
	}  then  {
		deny;}
Please let me know if my understanding is wrong.
Can you share the packet that should be permitted but denied?
