A4 - High CPU utilization "SysIdleTask" process
  • Question
  • Updated 7 months ago
  • Answered
  • (Edited)
Hi
I installed a few A4 switches recently and realized that they are all showing high cpu utilization  in the "SysIdleTask" process.
Does anyone know what this can be?
Is it a normal behavior?
Photo of Obernan Cavalcante
Obernan Cavalcante
  • 134 Points 100 badge 2x thumb
Posted 1 year ago
Photo of Adilson Gal
Adilson Gal, Employee
  • 1,408 Points 1k badge 2x thumb
Yes, this is normal. The utilization of the CPU seems to be fine as well. Nothing to worry.
SysIdleTask means unused resources that are available to your system.
Photo of Jeremy
Jeremy, Embassador
  • 9,788 Points 5k badge 2x thumb
System IdleTask is the % of CPU that is not being consumed by a process.  So, seeing a low number like 10% would be bad.
Photo of Nick Yakimenko
Nick Yakimenko
  • 2,404 Points 2k badge 2x thumb
SysIdleTask is a remaining CPU load after all other tasks
e.g. you have summary load 8% then this "task" will have (but not use!) 92%
Photo of Daniel Coughlin
Daniel Coughlin, Employee
  • 2,702 Points 2k badge 2x thumb
That is the Idle task. Your switch is not very busy.
Obernan Cavalcante
Ok. Thank you for the answers and explanations. This was very enlightening
Hello
What, is the process name bcmRX??
Because the CPU in C5K is 90 %
Regards!!
