A Altitude AP has attempted to connect that is unknown to the system. Altitude AP authentication fai
  • Question
  • Updated 5 years ago
Create Date: Apr 4 2013 12:52PM
Hello!We have a WM2000 Wireless Controller and one of the Altitude APs, that used to work, cannot connect to WM anymore.In the log i have the following message: 04/03/13 17:38:00 Major RU Manager A Altitude AP has attempted to connect that is unknown to the system. Altitude AP authentication failure. Serial Number: xxxxxxx, IP: xxxxxxxxxx. I tried to turn it off and on, delete it from WM and it still cannot connect. Any help please?!Thanks in advance!
(from Gustavo_Oliveira)
Photo of EtherNation User
EtherNation User, Employee
  • 20,340 Points 20k badge 2x thumb
Posted 5 years ago
Create Date: Apr 4 2013 4:54PM
Are the AP and the controller in the same VLAN?
(from ethernet)
Create Date: Apr 4 2013 5:13PM
Hello!Yes, they are in the same VLAN, i can ping the old AP's IP address. Now it doesn't even show the error message in the log and one of the AP's keep rebooting.Any idea?
Create Date: Apr 4 2013 5:40PM
What kind of AP is that (model number)? How is it getting its IP address? via DHCP?
(from ethernet)
Create Date: Apr 4 2013 7:56PM
It's a Extreme Altitude 350-2 Integrated Antenna. It's IP is being assigned by DHCP but also i tried with static IP.
Create Date: Apr 4 2013 9:06PM
I had to reset the AP phisically (reset button) and then re-add it to the WM.Thanks for the help!
