Abnormal fan speed
  • Problem
  • Updated 3 years ago
  • Solved
  • (Edited)
Hi, all!
X440-24p
X440-24p.2 # show temp
Field Replaceable Units               Temp (C)   Status   Min  Normal   Max
Switch         : X440-24p               12.00    Normal   -10    0-48  55
X440-24p.3 # show fan
FanTray information:
 State:                  Operational
 NumFan:                 4
 Fan-1:                  Operational at 11000 RPM
 Fan-2:                  Operational at 11000 RPM
 Fan-3:                  Operational at 11000 RPM
 Fan-4:                  Operational at 11000 RPM
But full speed have to be in 30C temperature.
(I know that fan speed is controllin from other temp controller, but it's can't be so beeg difference beetween 2 controllers)
With my temperature there have to be half-spees of fans.
Any ideas?
Thank you!
Photo of Alexandr P
Alexandr P, Embassador
  • 12,768 Points 10k badge 2x thumb
Posted 3 years ago
Photo of Karthik Mohandoss
Karthik Mohandoss, Employee
  • 6,168 Points 5k badge 2x thumb
Photo of Alexandr P
Hello, Karthik!
In this article temperature shown 28,5C - which is near 30C - and it is normal when temp controller0 and controller1 can have not so big difference.
But in my case temperature 12C.
Thank you!
Hi Alexandr,
I would say that the output provided in the article is just for sample not meant to point temperature reading.
"EXOS cannot determine the fan speed, as the fan speed is set by a hardware fan controller. This controller only reports the fan status (either operational or failed)."
Photo of Alexandr P
Ok.
In your article there is information:
X440-24p 5900 (half-speed)  11000 (full-speed)
When I'll take 5900RPM?
Thank you!
Hi Alexandr,
This information "X440-24p 5900 (half-speed)  11000 (full-speed)" is taken from the Datasheet on how exactly the fan behaves to high and low temperature levels, where in EXOS cannot determine the fan speed so in "show temp" it is getting displayed as 11000 RPM when the fan is operational regardless of full/half speed.
Here is a output from Lab switch which could clear the confusion.
# show temp
Switch         : X440-24p               10.00    Normal   -10    0-48  55
# show fan
 State:                  Operational
 NumFan:                 4
Photo of Alexandr P
Thank you!
