About Disabling Flow Control on the S/N/K-Series
  • Article
  • Updated 5 years ago
  • (Edited)
Article ID: 13285
Products
S-Series
Matrix N-Series DFE
K-Series
Discussion
On these products as long as Flow Control is advertised it will continue to function - even when disabled.
Though this behavior is considered to be Functions as Designed (FAD), it is still counter-intuitive.
To disable Flow Control on a port:
set port flowcontrol <port#> both disable
clear port advertise <port#> bpause
To re-enable Flow Control on a port:
set port flowcontrol <port#> both enable
set port advertise <port#> bpause
To review the result, in either case:
show port flowcontrol <port#>
show port advertise <port#>
Note that Flow Control - which uses IEEE 802.1x Pause frames - only applies to ports operating in Full Duplex mode. Half Duplex ports, on the other hand, use a transmitted collision signal to elicit a flow control effect on peer devices.
See also: 6835 and 15084.
Photo of FAQ User
FAQ User, Official Rep
  • 13,610 Points 10k badge 2x thumb
Posted 5 years ago
There are no replies.
