Access Point still showing on Wireless Controller as offline after being physically removed (WM3400 & AP4600)
  • Problem
  • Updated 3 years ago
  • Solved
I'm currently using a WM3400 with AP4600s. (4620 in this case)  We removed the AP4620 and replaced it, however it still appears on the web interface as offline.  Is there a way to remove this AP from the controller so that others won't panic when they see the interface?
Photo of Sean Tutor
Sean Tutor
  • 484 Points 250 badge 2x thumb
Posted 3 years ago
Photo of Brandon Clay
Brandon Clay, Escalation Support Engineer
  • 13,086 Points 10k badge 2x thumb
Hi Sean,
If you log into the CLI of the controller, then go into config mode, you can just do 'no ap4600 '. This will delete the device config for this AP.
-Brandon
(Edited)
Photo of Sean Tutor
Sean Tutor
Do I need to write to memory or anything else?
Yes, you will need to commit the changes and then save the config.
Photo of Sean Tutor
Sean Tutor
Thanks. :)  It was still there after I ran the command.  For some reason the AP still showed up in the Config tab at which point I realized there's a delete button.... /sigh  I deleted it and then commit/write and it went away from the dashboard.  Appreciate the help!  You can close this ticket!
