Accesspoint as device in Netsight
  • Question
  • Updated 2 years ago
  • Answered
Hi guys,
is it possible to add wireless accesspoints as a device in Netsight/OneView?
Customer wants do see offline APs quicker in Device View.
Thank you,
regards,
Stephan
Photo of Stephan
Stephan
  • 464 Points 250 badge 2x thumb
Posted 2 years ago
Photo of David Coglianese
David Coglianese, Embassador
  • 5,944 Points 5k badge 2x thumb
I have added AeroHive APs to NetSight but unless you get them static IPs  you could lose them.
That was not an issue for me as I was just testing functionality.
The other think to be mindful of is how many devices you are licensed for.
Photo of Stephan
Stephan
Is that also possible with the Extreme APs? I dont't see how to establish SNMP connection..
I just took the wireless class and have not had a chance to play with those yet.
Photo of Thomas, Frank
Thomas, Frank, Employee
  • 1,902 Points 1k badge 2x thumb
The Extreme Aps don't have an snmp agent. They generally managed by the controller.
You can model it with Ping.
Photo of Pala, Zdenek
Pala, Zdenek, Employee
  • 8,474 Points 5k badge 2x thumb
you can add the controller to NetSight with both SNMP and CLI credentials. then NetSight will configure traps & syslog receiver on controller = you can configure it manually also :).
On the controller define the AP poll timeout. When the AP is lost, the controller will report it to NetSight.
All is prepared and easy to deploy.
good luck
