ACL for applying over VLAN
Alok_Shukla
New Contributor III
We have 4 VLAN over Core Switch (MLAG configured)
VLAN 1: 10.3.1.0
VLAN 2: 10.3.2.0
VLAN 3: 10.3.3.0
VLAN 4: 10.3.4.0
we don't want VLAN-3 and VLAN-2 to communicate with VLAN-1.
But VLAN-2 and VLAN-3 should communicate each other.
Help to apply me what ACL should be applying?
7 REPLIES 7
Alok_Shukla
New Contributor III
It's not working, still pinging both VLAN
yes, we had applied on ingress direction but still, both VLAN can ping each other.
Note If an ACL needs to be installed for traffic that is L3 routed, and the ingress/egress ports are on different packet-processing units or different slots, and any of the following features are enabled, we recommend that you install the policy on a per-port basis rather than applying it as a wildcard, or VLAN-based ACL. • MLAG (Multi-switch Link Aggregation Group) • PVLAN • Multiport-FDB (forwarding database)
Aman
New Contributor II
** count Corp_Vlan_3 in last statement.
I also doing first time so it could be wrong , but it should work.
Aman
New Contributor II
did you apply on the Ingress direction?
