ACL issue for QoS
  • Question
  • Updated 2 years ago
  • Answered
I am trying to classify traffic on ingress port/vlan and remark DSCP values in them. Not sure if I use only "if" statement or "if match any/all" statement? What is the difference between any and all?
I also got an error while trying to use the ACL via a policy file.
"Error: Policy Test has syntax errors
Line 4 : Attribute source-address already exists as a match statement in Acl entry. "
CLI given below:-
SWT-01 # vi qos-1.pol
entry replace_DSCP_40 {
if match all {
 source-address 10.53.5.16/29 ;
 source-address 10.53.5.24/29 ;
 source-address 10.53.5.32/30 ;
 source-address 10.53.5.36/30 ;
 source-address 10.53.5.40/30 ;
 source-address 10.53.5.44/30 ;
 source-address 10.53.5.48/28 ;
 source-address 10.53.5.64/28 ;
 source-address 10.53.5.80/30 ;
 source-address 10.53.5.84/30 ;
 source-address 10.53.5.88/30 ;
 source-address 10.53.5.92/30 ;
then {
    qosprofile qp8 ;
    replace-dscp  ;
configure diffserv replacement qp8 code-point 40
configure access-list qos-1 VLAN/PORT [ingress|egress]
save
Photo of Sumanta Ghosh
Sumanta Ghosh
  • 458 Points 250 badge 2x thumb
Posted 2 years ago
Photo of Patrick Voss
Patrick Voss, Alum
  • 11,594 Points 10k badge 2x thumb
Hello Sumanta,
You will need to make those individual entries. You cannot have multiple match conditions be the same in one entry.
Photo of OscarK
OscarK, ESE
  • 7,912 Points 5k badge 2x thumb
You can only use match statement source-address once in every entry. The only ACL where it is possible to have multiple match statements with the same keyword are nlri match statements that are used in bgp for example.
Photo of Henrique
Henrique, Employee
  • 10,302 Points 10k badge 2x thumb
Hi Sumanta,
"if match all" means all match condition lines must be true to take the defined action
"if match any" means just 1 line must be true to take the defined action
For access-list you cannot repeat the same match condition. That means you have to create 1 rule for each IP (using the same .pol file).
Example:
entry replace_DSCP_40_a {
if match all {
then {
    qosprofile qp8 ;
    replace-dscp  ;
entry replace_DSCP_40_b {
if match all {
then {
    qosprofile qp8 ;
    replace-dscp  ;
entry replace_DSCP_40_c {
if match all {
then {
    qosprofile qp8 ;
    replace-dscp  ;
And so on...
Sumanta Ghosh
Hi All
Many thanks for all your help. I'll try accordingly and let you know.
