ACL policy to restrict telnet is not working as desirable
Francisco_Leitã
I'm new using extreme switches. I have configured the following ACL policy to allow only the networks listed in the policy to connect by telnet to the switch model X480-24X, running ExtremeXOS version 15.6.4.2, however only the host with IP address 200.20.76.42 is connecting the others are being rejected.
Has anyone ever faced this problem?
Entry AllowTheseSubnets {
if match any{
source-address 200.20.76.42 /32;
source-address 187.111.111.5 /32;
source-address 200.20.66.176 /27;
then
permit ;
Tks in advance
6 REPLIES 6
Francisco_Leitã
I hadn't done that! To be honest I had no idea this command was required when you change an ACL. After issuing the refresh command the ACL worked fine!
As I had told I am new in Extreme switches.
Tks!
No problem, we are here to help. Welcome by the way.
StephenW
did you refresh the policy?
Francisco_Leitã
Hi Stephen,
First of all thanks for your attention,
I have configured the ACL as you suggested, even so, It's not working. Following you can see the message in the log informing the connection has been rejected.
SW-IPLAN.5 # show log
05/03/2018 15:21:28.59 Telnet connection from source 187.111.111.5 has been denied by access-list IplanAcesso. Rejecting connection.
Tks!
