ACL Basic
  • Question
  • Updated 4 years ago
  • Answered
Create Date: May 3 2013 2:16PM
HiI'm not quite getting ACL's so far. I have a few vlans all with ipforwarding enabled and ips for the vlans.vlan 1 10.10.1.0/24vlan 2 10.10.2.0/24
I was hoping the following would allow ping from vlan 1 to vlan 2 but block all else, but it doesn't seem to work, do i need to also allow the return traffic or am i incorrect..so if i create this policy (below) and configure via :
configure access-list thepolicy vlan "Vlan 2"
Code:
@description "Allow ICMP ping"
entry ping_allow_echo_request
  if {
    protocol icmp;
    icmp-type echo-request;
    source-address 10.10.1.0/24;
  } then {
    permit;
@description "Default block all"
entry deny_default_all {
  if {
  then {
    deny;
(from conrad_jones)
Photo of EtherNation User
EtherNation User, Employee
  • 20,340 Points 20k badge 2x thumb
Posted 4 years ago
Create Date: May 3 2013 7:18PM
You have to allow the return as well. ACLs in XOS aren't stateful. If you allow the echo requests back, you should get the result you want.
(from Ansley_Barnes)
Create Date: May 5 2013 6:22PM
got it working, added echo-reply to the same network but as destination network
thank you
Code:
  if {
    protocol icmp;
  } then {
    permit;
entry ping_allow_echo_reply
  if {
    protocol icmp;
    icmp-type echo-reply;
    destination-address 10.10.1.0/24;
  } then {
    permit;
  if {
  then {
    deny;
(from conrad_jones)
