Active APs not showing in OneView wireless dashboard
Ashish_Sahu
I have the following are being displayed correctly as expected:
1.OneView Wireless Overview displays correctly the number of APSs, wireless controllers and client.
But, the Wireless Dashboard doesn't display the following :
1.Clients
2. Active APs
3. Wireless Bandwidth
4. Network Bandwidth.
Kindly help. I'm facing a very critical problem which needs to be solved asap.
Thank you.
Ashish.
5 REPLIES 5
Doug
Take a look at the following article, https://gtacknowledge.extremenetworks.com/articles/Solution/OneView-displays-SYNC-ERROR-CLI-AUTHENTI...
Did you configure or change the controller CLI credentials?
Doug Hyde
Director, Technical Support / Extreme Networks
Doug
I would suggest contacting a GTAC Support Engineer again through the case ticket for further troubleshooting. If we find anything else out in the meantime, we will post an update for you here.
Doug Hyde
Hi Doug.
Thanks for the reply.
The CLI credentials were changed by one of the Extreme TAC Engineer through a remote session, in order to make a necessary change.(The moment CLI credentials were changed the APs got synchronized with OneView)
Under Netsight Wireless Manager -> Controller data Synchronization
What should I do next to get this resolved ?
I've got all the APs displayed and showing up, but the Wireless dashboard doesn't show the 2 controllers, Active APs, Clients and Bandwidth.
Thanks!
