Added 3825e to C25 Controller, won't go active?
  • Question
  • Updated 3 years ago
  • Answered
I just opened a new site. Added the appropriate licenses to my C25 controller, and installed 6 new AP's. I can get the controller to see them, but I can't get them to go active. Configs appear good and complete, but the radios stay off, and the topology box shows "Inactive".
I do have the radios enabled on the radio pages.
What could I be missing? I just copied the configs from my other AP's to the new ones.
Photo of Don Tuleja
Don Tuleja
  • 202 Points 100 badge 2x thumb
  • Frustrated
Posted 3 years ago
Photo of Jeremy
Jeremy, Embassador
  • 9,788 Points 5k badge 2x thumb
Go to the AP properties and click on the "Professional Install" button and select the antennas you are using.  Then make sure Radio 1 and Radio 2 are set to "on".
Photo of Don Tuleja
Don Tuleja
Thanks,
Yeah, did that too. :(
Pic here: http://i.imgur.com/Ic1dPvV.png
Photo of Jeremy
Jeremy, Embassador
Is your country set?
Photo of Don Tuleja
Don Tuleja
On the AP Properties tab? Yes. It's set to United States.
Photo of Christoph
Christoph
  • 1,842 Points 1k badge 2x thumb
You need to configure a whole VNS with Topology, Roles and WLAN Service and enable it all. Then you have to assign the WLAN Service to the AP.
If an AP has no active VNS (with active WLAN Service) assigned it won't activate the the radio.
Just try to use the VNS Wizard.
Photo of Don Tuleja
Don Tuleja
This is an existing environment. The VNS are showing assigned to the AP's.
Photo of Ronald Dvorak
Ronald Dvorak, Embassador
  • 49,992 Points 20k badge 2x thumb
"I just opened a new site." - is that a remote site, could be a MTU problem.
Please check out this post and look whether the AP is fully registered (log message - blacklist send)....
https://community.extremenetworks.com/extreme/topics/remote_aps_fail_to_connect_to_controller
-Ron
Photo of Tomasz Lubas
Tomasz Lubas
  • 534 Points 500 badge 2x thumb
Check all ap logs and check if antennas are properly installed.
Photo of Joseph Burnsworth
Joseph Burnsworth
  • 2,328 Points 2k badge 2x thumb
Any time you do a remote site install you should set the MTU on the AP's to 1300
If you can configure them before shipping, it is very easy in the GUI
If you need to SSH into them and change them manually, the commands are
Username: admin
Password: new2day
cset staticMTU 1300
capply
csave
You will have to wait about 30 seconds before you get a confirmation that the settings have saved
Once saved you can reboot them with the reboot command
Please let me know if this helps :)
Photo of Doug Hyde
Doug Hyde, Technical Support Manager
  • 20,606 Points 20k badge 2x thumb
Photo of Doug Hyde
Don,
If you are still having issues, I would give GTAC a call so we can review the setup and assist.
Thanks,
Doug
Photo of Don Tuleja
Don Tuleja
Well, I tried to SSH into them, and they're not responding. I've rebooted the switch they're connected to, and still they don't even respond to ping. There's something else going on. I appreciate the helps so far. Once I'm able to connect to them via SSH I'll post here.
Photo of Don Tuleja
Don Tuleja
YAY!
My telco changed the MPLS gateway on me. Fixed that and everything is working as it should.
Thanks!
Joseph Burnsworth
Awesome! Very happy to hear that :)
