Adding a second PSU 10931 module on X460
  • Question
  • Updated 10 months ago
  • Answered
Dear Community
If I want to add a second internal power supply to a Summit X460, should I first switch off the switch, or can you connect the PSU 10931 module "hot"?
Is there any configuration ?
Photo of AIT Support
AIT Support
  • 150 Points 100 badge 2x thumb
Posted 10 months ago
Photo of Naresh
Naresh, Employee
  • 1,232 Points 1k badge 2x thumb
PSU is hot swappable. You can directly connect to the PSU to the switch and there is no configuration to be done on the switch.
Photo of Tripathy, Priya Ranjan
Tripathy, Priya Ranjan, ESE
  • 2,306 Points 2k badge 2x thumb
I could see my colleague Naresh has already answered for your queries here. But to add more to this in case if you want to know the PSUs which are all compatible with X460G2 hardware  then before adding them to the device better to cross verify this link below to find out the compatible PSUs for the same hardware in the future:
Let us know if you have any further queries to address here......
