Adding an existing untagged member port of vlan Default as tagged can cause STP configuration loss.
  • Question
  • Updated 1 week ago
  • Answered
New to Extreme switches, and using EXOS version 22. Why do I see this message when adding the same port tag and untagged. Adding an existing untagged member port of vlan Default as tagged can cause STP configuration loss.
Photo of nola saint
nola saint
  • 250 Points 250 badge 2x thumb
  • frustrated. Cant find a solid answer.
Posted 2 months ago
Photo of Sushruth Sathyamurthy
Sushruth Sathyamurthy, Employee
  • 784 Points 500 badge 2x thumb
I believe MSTP is enabled on 22.x by default. By default, the Default untagged VLAN is used as the Carrier VLAN for the s0 STP domain.  However, once ports are removed from the Default VLAN or the VLAN is disabled, a tagged Carrier VLAN must be defined if STP will be enabled in the network. I think this is the reason you get the warning message.
Photo of Grosjean, Stephane
Grosjean, Stephane, Employee
  • 12,754 Points 10k badge 2x thumb
that has been introduced with 22.2. You need to start with a default factory config from that version (or above) to see it by default.
Photo of nola saint
nola saint
What is the impact of the statement?  Also, how can I avoid this from happening again.
I do not believe this statement has an impact. It is merely a warning message as per your carrier VLAN configuration. The Default untagged VLAN is the carrier VLAN for the s0 STP domain. If you change that, this warning message will appear as carrier VLAN must be present for all STP protected ports.
Photo of nola saint
nola saint
Thanks, it helps a little.  Do you have any real-world examples of why, when, where and how to implement this?
I'm not sure I understand your question. Are you needing configuration example in a switch? https://gtacknowledge.extremenetworks.com/articles/How_To/How-to-configure-RSTP-in-EXOS
Photo of nola saint
nola saint
After configuring other switches I read again one of your post and I think I understand that its just a warning.
  • Like
