Adding/configuring access point to controller before they are physically installed
  • Question
  • Updated 1 year ago
  • Answered
Is it possible to add/configure APs prior to them being physically installed.  I have a new building going up and we will be installing 40+ APs.  I'd like to be able to provision and configure the APs in advance.  Is that possible on the C5210 controllers?
Thanks,
-Rich P.
Photo of Rich Pacheco
Rich Pacheco
  • 966 Points 500 badge 2x thumb
Posted 1 year ago
Photo of Darin Seiler
Darin Seiler
  • 402 Points 250 badge 2x thumb
Yes we do this all the time. We inbox the AP, plug it in at Corporate to configure it, unplug and box the AP back up and take it out to a building for install. Our installs can take months since we have really large buildings. We have two c5210s in an HA pair and typically are putting 3935e and i's on them.
Photo of Sudip Sarkar
Sudip Sarkar
  • 130 Points 100 badge 2x thumb
Yes it's very much possible, only check the licences...
Darin Seiler
Unbox not Inbox I meant. iPhone autocorrect:-(
Rich Pacheco
Thanks... is there a way to do it without "unboxing" the AP?  I'm hoping I can just scan the SN on the side of the box and somehow use that to register the AP with the controller.  Once I have the AP in the controller, I can set the channels and power and I'm hoping that once the AP physically installed, it will connect to the controller and start working.
Photo of Ostrovsky, Yury
Ostrovsky, Yury, Employee
  • 3,050 Points 3k badge 2x thumb
Yes , all you need to is the AP serial number and AP platform . You can do it manually in the Controller GUI (Add AP) . There is also some way to script it.
Photo of Ronald Dvorak
Ronald Dvorak, Embassador
  • 50,114 Points 50k badge 2x thumb
But don't expect that a static IP config will work
Photo of Peter Chang
Peter Chang
  • 394 Points 250 badge 2x thumb
We went with this method as well when we were replacing our wireless with Extreme Wireless. Our infrastructure was already in place, and with the limited time we had for an install, all we did was scan the serial into EWC, ensured our default settings were in place, labelled the AP, then handed the box to our contractor to physically complete the installation.
Darin Seiler
Yes as Yury explained. We like to unbox so we can label each AP as well as have the firmware match the controller before taking to a remote building (takes longer on initial boot if firmware doesn't match and bandwidth concerns)...
Rich Pacheco
Thanks.. this was very helpful.
Please send me email to yostrovs at extreme , I will give you the script with instructions
Photo of Pascal Lurquin
Pascal Lurquin
  • 970 Points 500 badge 2x thumb
Don't forget to put settings on default AP !
Especially if the model are not the same ...
