Adding new APs, and they are showing up as "Inactive"
  • Problem
  • Updated 2 years ago
  • Solved
I'm installing new APs, and I can approve the APs, but they are showing up as "Inactive". They have a 00.00.00.00 addresses. I have tried rebooting, pending, moving to a different data drop, but I still can't get the APs to come up.
Photo of Laura
Laura
  • 1,490 Points 1k badge 2x thumb
Posted 2 years ago
Photo of Ronald Dvorak
Ronald Dvorak, Embassador
  • 50,114 Points 50k badge 2x thumb
Could you provide model number and serielnumber just to check it's not this issue...
https://community.extremenetworks.com/extreme/topics/new-aps-show-as-inactive
Photo of Laura
Laura
12461288235N0000 is the Serial#
AP3605 is the model
Photo of Laura
Laura
AP3605 is the model
Photo of Umut Aydin
Umut Aydin, Escalation Support Engineer
  • 2,300 Points 2k badge 2x thumb
Hi Laura,
try to set the AP to factory default and clear it from the Controller.
Chnage the Controller to controlled upgrade.
Maybe it's trying to do an uodate and it's not possible.
If you change to controlled upgrade it should maybe come with his own code.
Maybe the AP FW code is to old and the upgrade to this version is not possible.
Do you have another AP3605 on cour controller?
Otherwise attache to the console of the AP and look what he is trying.
Serial port for the console
115200
username:admin
password:new2day
Ask for his version
# cd /etc
# cat ap_version.txt
#!/bin/sh
export AP_VERSION=09.21.11.0004
export AP_IMAGE_TYPE=00000006
export BOARD_TYPE=ngap_p2
# cget c g ( config of the AP)
# tail -f /tmp/log/ap.log
Another option would be configure the AP manually.
Telnet/ssh to the AP or over the console port:
Login to AP, type following command:
cset dhcpc disable
cset ipaddr x.x.x.x ( IP Address of the AP)
cset ipmask x.x.x.x
cset authip 1 x.x.x.x            #HWC esa port IP address
or this it depends on AP Type
set authipaddrs 1 x.x.x.x
(You can check this if you ask for the AP config via # cget c g)
capply
csave
reboot
If this doesn't help also please open a case with GTAC.
Good luck.
regards
Umut Aydin
Photo of Laura
Laura
What is the difference between these 2 "Upgrade Behavior" settings? What should it be on? It was on "Always upgrade", but I just changed it to "Upgrade when", because the APs that I have installed are not coming up, they are still saying Inactive in the Topology.
Photo of Laura
Laura
Also, when I SSH into the AP, it says:
#!/bin/sh
export AP_VERSION=08.11.01.0161
, but the controller and other working APs say 9.21.10.5
Always upgrade = as the AP connects to the controller the software is upgraded/downgraded to the default AP image which is generally/default the same software version that is running on the contoller
Upgrade when = you as a admin of the system could perform the upgrade/downgrade manually
It comes handy if you upgrade a controller pair and don't want to upgrade all APs at once (always upgrade) instead you could upgrade some APs at a time, wait till they are up and then upgrade some more (=upgrade when).
If the AP is not connected to the controller it's normal that you don't have the same software as the controller.
So fix the connection issue and the AP will connect and upgrade (if always is selected which you should set),
(Edited)
Photo of Laura
Laura
I'll just leave it on, "Always.." My APs are still showing as 'Inactive" and not coming up in the controller. MAC address shows 0000000s. They are on the network. I can ping and ssh to the AP. But the controller wont update the APs settings. I put in a work order, but havn't heard anything yet.
 I also did the #tail -f /tmp/log/ap.log
I got this:
an  1 00:04:22 cap: 00180:ru_mgmt.c:2083-whsl_trans()-S_EDISC 64
Jan  1 00:04:23 cap: 00180:ru_mgmt.c:2083-whsl_trans()-S_EDISC 63
Jan  1 00:04:24 cap: 00180:ru_mgmt.c:2083-whsl_trans()-S_EDISC 62
Jan  1 00:04:25 cap: 00180:ru_mgmt.c:2083-whsl_trans()-S_EDISC 61
Where do I look to find out what this means?
(Edited)
could you ping the controller interface that is enabled for AP registration from the AP CLI ?
also if you do "cget config global" please check the result for DHCP mode, IP, mask, gateway....
does the output show a IP that a AP should get in this subnet
Photo of Laura
Laura
I was able to ping from the AP to the controller. I compared a working APs output to an Inactive AP:
I notice the Inactive AP doesn't have the ip addresses for:
lastAcIp (controllers ip)
authIpAddr 1
failover bmIp [1]
failover bmIp [1]
It does have it's correct ip address: These settings are there.
dhcp mode enable (1)
ip 10.17.29.45
mask 255.255.0.0
gateway 10.17.255.254
(Edited)
if the DHCP server is configured to provide the controller IP (option 78) I'd factory reset the AP to try if that solves it.
# cset fact
In case that doens't work try to set it static with ... (x.x.x.x = controller IP)
# cset authip 1 x.x.x.x
# capply
# csave
wait til it's saved and reset the AP
Might be also a good idea to delete the AP from the controller before you do what I've mentioned above.
Photo of Umut Aydin
Hi Laura,
could you please confirm if it's working now with the recomendations for other audience.
If not you should open a case with GTAC.
Thanks
Regards
Umut Aydin
Photo of Laura
Laura
It's not working yet. I have a ticket in with GTAC.
Photo of Drew C.
Drew C., Community Manager
  • 40,218 Points 20k badge 2x thumb
Hi Laura, was GTAC able to provide you with a resolution that you can share here?
Photo of Joe Kozura
Joe Kozura
  • 212 Points 100 badge 2x thumb
i had this issue...it was resolved by approving the AP and turning ON both radios, they were admin'd down for some reason
Photo of Careno, Ryan
Careno, Ryan, Employee
  • 1,092 Points 1k badge 2x thumb
The issue is now resolved.  When APs are using DNS discovery method for controllers there should be two DNS records pointing to both controllers in a High Availability Pair:
https://gtacknowledge.extremenetworks.com/articles/How_To/How-To-Configure-an-AP-to-find-the-IdentiF...
