Adding WS-AP3805I to C25 Controller
  • Question
  • Updated 2 years ago
  • Answered
Hi I'm adding 6 new AP WS-ap3805I to a C25 controller.
- how I set an ip to the AP
- If I try to add an AP in the controlle first I don't have the selected model in the dropdown list, and then it told me that the serial is incorrect.
Can somebody help me?
thank you
Carlo
Photo of Carlo Del Pietro
Carlo Del Pietro
  • 70 Points
Posted 2 years ago
Photo of Ronald Dvorak
Ronald Dvorak, Embassador
  • 47,404 Points 20k badge 2x thumb
What software version is running on the controller.
You need to provide a IP via DHCP to the AP, you could only configure the AP if the AP is connected to the controller.
If the AP has an IP in the same subnet as the controller he should be able to discover the controller.
Photo of Gareth Mitchell
Gareth Mitchell, Extreme Escalation Support Engineer
  • 5,578 Points 5k badge 2x thumb
Photo of Carlo
Carlo
  • 134 Points 100 badge 2x thumb
software huol be Software: 09.12.03.0009
The Ap is connected (via switches) to the controller but there is no dhcp on that port
Carlo
.... so following Gareth I need to upgrade ....
(Edited)
As per Gareth's post above ....
  • The minimum firmware version needed to support the WS-AP3805i is 9.15.01.0121
So you need to upgrade the controller and also enable a DHCP server so that the AP could get a IP.
Photo of Carlo
Carlo
I'm searching bu here's simple .. where I download the firmware?
The configuration will not be touched with the upgrade (so I will not lost anything)?
Photo of Carlo
Carlo
Thank you Gareth
I talk with GTAC guys ... the customer has no maintenance contract so no upgrade
thank you!
Carlo
Photo of Ryan Mathews
Ryan Mathews, Alum
  • 8,988 Points 5k badge 2x thumb
Thanks for closing this out with the Hub Carlo.
Hopefully you can help this customer up with a service strategy going forward that will allow them to get the latest code they need.  Appreciate your trust in and advocating for Extreme.
