Adding on X450e-48p to an existing OSPF network
  • Question
  • Updated 4 years ago
A previous network engineer setup OSPF throughout our network, he has since left. I just finished & passed my CISCO CCENT, so while I’ve just finished learning and practicing OSPF I’m still inexperienced.
I’m tasked with setting up a new office, which has an Ethernet connection to our extreme switch and we want to disable OSPF on the router in front of the switch and use the new line / extreme switch. I have the cmd to turn off OSPF on the router, but my question is how OSPF works via Extreme OS, I’ve downloaded Extreme’s admin guide and read through it, however I’ll show code that I’m not sure on.
On other extreme switch that is running OSPF correct:
enable ospf
enable ospf export direct cost 1 type ase-type-1 – what does this mean?
enable ospf export static cost 1 type ase-type-1- same as above
configure ospf add vlan Backbone area 0.0.0.0
configure ospf vlan Backbone priority 0
configure ospf add vlan XO-VPLS-MESH area 0.0.0.0
My code on the switch I configured.
enable ospf
enable ospf export direct cost 10 type ase-type-1
enable ospf export static cost 10 type ase-type-1
configure ospf vlan CTAP-Agent priority 0 – Not sure why these vlans auto appeared, I only configured the vlan XO_VPLS for ospf
configure ospf vlan EVN priority 0 - similar
configure ospf vlan IPC priority 0 – similar
configure ospf vlan IVN priority 0 - similar
configure ospf add vlan XO_VPLS_MESH area 0.0.0.0
configure ospf vlan XO_VPLS_MESH priority 0
I deleted the default route to the router, since I want all traffic to go out the XO line, with ospf, I should need a default route?
I am also noticing that on the HQ iproute table it shows the vlans EVN, IPC, etc as (d) - direct connect? why is it not listing them as OSPF?
Thanks
Photo of Sidney Yoder
Sidney Yoder
  • 190 Points 100 badge 2x thumb
Posted 4 years ago
Photo of PARTHIBAN CHINNAYA
PARTHIBAN CHINNAYA, Alum
  • 4,362 Points 4k badge 2x thumb
We are redistributing static and directly connected routes to ospf.
configure ospf vlan CTAP-Agent priority 0 – Not sure why these vlans auto appeared, I only configured the vlan XO_VPLS for ospf .
EXOS 15.3.1.4-patch1-30 --we have this default config added to the ospf config which cant be deleted.this should have been fixed in recent release.
I need to know the topology to answer this query.
Need more information for this query as well.
Sidney Yoder
Does the below information help?
Slot-1 CTAP-Cosmo-Stack.9 # show ospf inSlot-1 CTAP-Cosmo-Stack.9 # show ospf interfaces
 VLAN      IP Address         AREA ID         Flags      Cost State   Neighbors
CTAP-Agent 192.168.112.1  /24 0.0.0.0         --if-       4/A -----     0
EVN        10.20.50.1     /24 0.0.0.0         --if-       5/A -----     0
IPC        172.16.50.1    /24 0.0.0.0         --if-       5/A -----     0
IVN        192.168.50.1   /24 0.0.0.0         ---f-       4/A -----     0
XO_VPLS_ME 10.128.254.4   /24 0.0.0.0         --if-       5/A -----     0
lot-1 CTAP-Cosmo-Stack.13 # show iprou
Slot-1 CTAP-Cosmo-Stack.13 # show iproute
Ori  Destination        Gateway         Mtr  Flags         VLAN       Duration
#s   Default Route      192.168.112.2   1    UG---S-um--f- CTAP-Agent 1d:22h:46m:11s
#d   10.20.50.0/24      10.20.50.1      1    U------um--f- EVN        6d:22h:4m:30s
#d   10.128.254.0/24    10.128.254.4    1    U------um--f- XO_VPLS_MESH 6d:22h:4m:30s
#d   172.16.50.0/24     172.16.50.1     1    U------um--f- IPC        6d:22h:4m:30s
#d   192.168.50.0/24    192.168.50.1    1    U------um--f- IVN        6d:22h:4m:30s
#d   192.168.112.0/24   192.168.112.1   1    U------um--f- CTAP-Agent 6d:22h:4m:30s
Slot-1 CTAP-Cosmo-Stack.14 # show vl
Slot-1 CTAP-Cosmo-Stack.14 # show vlan
Name            VID  Protocol Addr        Flags                Proto  Ports  Virtual
        Active router
        /Total
CTAP-Agent      500  192.168.112.1  /24  -f-------o--------------- ANY    81/134 VR-Default
Default         1    --------------------------------------------- ANY    0 /0   VR-Default
EVN             501  10.20.50.1     /24  -f-------o--------------- ANY    1 /3   VR-Default
IPC             502  172.16.50.1    /24  -f-------o--------------- ANY    1 /4   VR-Default
IVN             503  192.168.50.1   /24  -f----------------------- ANY    1 /7   VR-Default
Mgmt            4095 --------------------------------------------- ANY    0 /1   VR-Mgmt
XO_VPLS_MESH    1000 10.128.254.4   /24  -f-------o--------------- ANY    1 /1    R-Default
My HQ Extreme switch
#o1  192.168.254.64/26  10.1.1.1        5    UG-D---um--f Backbone   39d:5h:4m:15s
#o2  192.168.254.128/26 10.1.1.1        21   UG-D---um--f Backbone   13d:0h:26m:42s
#d   192.168.254.224/27 192.168.254.226 1    U------um--f Polycom    123d:22h:8m:38s
#o1  198.105.200.0/23   10.128.254.1    5044 UG-D---um--f XO-VPLS-MESH 14d:2h:38m:6s
#o1  198.105.200.0/23   10.128.254.2    5044 UG-D---um--- XO-VPLS-MESH 14d:2h:38m:6s
 s   216.30.107.208/30  216.149.3.149   1    -G---S-um--- -          123d:22h:8m:35s
