Adoption of WiNG based wireless on untagged VLAN
  • Question
  • Updated 1 year ago
  • Answered
I've got a site with about 150 WiNG based AP's. They adopt on V67 and as such, this is the default untagged vlan for each port they're connected to. For some reason, when I tell the AP's that this is V67 (as opposed to 1) in their profiles, they don't provision.  So they think that the untagged port they're on in 1 when in fact it's 67.  Why does this matter?  We're implementing a new management platform and since it's pulling the AP configs and they don't mesh with the actual settings, it's messing up everything.  Any thoughts as to why the AP's won't work when the profile says that their default vlan is 67 (bridging at the interface)?  These are nearly all 4532 and 4522 devices.
Photo of Eric Burke
Eric Burke
  • 2,424 Points 2k badge 2x thumb
Posted 1 year ago
Photo of Shay Weir
Shay Weir
  • 1,648 Points 1k badge 2x thumb
Try changing the AP switchport interface to: switchport trunk native vlan 67, switchport mode trunk
Photo of Eric Burke
Eric Burke
It's an EXOS x440, so the ports are set to "conf v67 add port n untagged" then two "tagged" for the BSSID vlan's.
Photo of Phil Frederick
Phil Frederick, Employee
  • 138 Points 100 badge 2x thumb
Do you have your tagged and untagged vlans defined on ge1?
interface ge1
  no switchport trunk native tagged
  switchport trunk allowed vlan 5,6,7,8...
Just to make sure, you're also assigning your management IP to vlan 67, correct?
interface vlan67
ip address dhcp
or if you are using device overrides for static IPs, for each AP config:
interface vlan67
  ip address <AP IP ADDRESS HERE>
(Edited)
Photo of Eric Burke
Eric Burke
Hi Phil.  Here's the config (done in via the controller UI, but seems to match [except for the wrong vlan]):
interface ge1
  description "Trunk to local switch"
  switchport trunk native vlan 1
  switchport trunk allowed vlan 1,60-68
  ip dhcp trust
  qos trust dscp
  qos trust 802.1p
 interface vlan1
  ip address dhcp
  ip address zeroconf secondary
  ip dhcp client request options all
Change "vlan1" to "vlan67"
interface ge1
  ip dhcp trust
  qos trust dscp
  qos trust 802.1p
 interface vlan67
  ip address dhcp
I'd also look at removing vlan 1 from your "switchport trunk" under ge1 if you're not using it.
Photo of Eric Burke
Eric Burke
Understood. That's what I was originally saying in the post.  If I set it to v67, it will not adopt.  It's set to trunk, as we're bridging at the ge1 interface so I assumed that was/is correct...
Photo of Shay Weir
Shay Weir
This is what we have and it works great...
interface ge1
switchport trunk allowed vlan 10,20,30,67,......
no lldp receive
no lldp transmit
interface vlan1
shutdown
interface vlan67
ip address dhcp
Ah, I see now. The root of the issue appears to be your APs are unable communicate with a controller using MiNT on VLAN 67, but can on VLAN 1. I'd start drilling down into the wired network at this point.
Is the controller local or remote? If local, is the controller's native VLAN also 67? If it's remote, is port 24576 allowed for VLAN 67?
What DHCP options are you pushing to the APs?
Is the AP getting a valid DHCP address on VLAN 67? Can you access the AP via SSH over VLAN 67?
Things like that.
(Edited)
Photo of Eric Burke
Eric Burke
I'm so confused...  :-)  There is a "vlan1" virtual interface set for DHCP.  I can't delete it, as when I try it says that it does not exist.  As such, I can't create a vlan67 virtual interface using DHCP (only one can use DHCP I believe), so when I try to commit - it fails.  The controller is also on V67 (untagged in the switch), but believes it's on V1 untagged too.  Been this way for 3 yrs or more.  All works fine except for the new mgmt tools (which think that the native Vlan for all of the AP's is the same as the LAN, which it's not).
Photo of Shay Weir
Shay Weir
The switchport and the GE1 interface need to have the same native vlan. "mint mclp vlan" should be enabled by default. If you add a controller host entry to point the AP to the IP address of the controller, then mint mlcp vlan should be disabled. AP communicates via IP instead of vlan to the controller. A more direct approach. Just a little more information to help.
Photo of Eric Burke
Eric Burke
Makes sense.  I ended up changing the vlan definition (for V1) to not use DHCP for gateway/DNS.  After doing so, and creating a new vlan definition (v67 with those options enabled), it grabbed an IP again.  The controller and AP's are on the same native VLAN, just not the one they think (they think it's V1, it's actually v67).  Again, was never a problem until I implemented our new mgmt platform and it got very confused.
Photo of Shay Weir
Shay Weir
Here is the controller profile. Hope this helps....
interface ge1
description Uplink
switchport trunk allowed vlan 10,20,30,67......
channel-group 1
interface ge2
description Uplink
channel-group 1
interface ge3
interface ge4
interface ge5
interface ge6
interface ge7
interface ge8
interface ge9
interface ge10
interface port-channel1
use event-system-policy
Photo of Eric Burke
Eric Burke
Am I the only one who thinks it's odd that we picked v67?
Photo of Shay Weir
Shay Weir
Not at all.
