Advert for VR on vlan X vrid 1 ignored: ignoring lower priority advert
  • Question
  • Updated 4 years ago
Hello,
Can someone please explain the meaning of the following. I am seeing this on my switches.
08/01/2014 02:13:58.52 <Warn:VRRP.Advert.Ign> Slot-1: Advert for VR on vlan DR_MNL_EXT vrid 1 ignored: ignoring lower priority advert
08/01/2014 02:13:58.50 <Warn:VRRP.Advert.Ign> Slot-1: Advert for VR on vlan DR_CH_LB vrid 1 ignored: ignoring lower priority advert
08/01/2014 02:13:58.50 <Warn:VRRP.Advert.Ign> Slot-1: Advert for VR on vlan PR_CEB_EXT vrid 1 ignored: ignoring lower priority advert
08/01/2014 02:13:58.46 <Warn:VRRP.Advert.Ign> Slot-1: Advert for VR on vlan DR_CEB_EXT vrid 1 ignored: ignoring lower priority advert
08/01/2014 02:13:58.28 <Warn:VRRP.Advert.Ign> Slot-1: Advert for VR on vlan EXT_INGRESS vrid 1 ignored: ignoring lower priority advert
08/01/2014 02:13:58.21 <Warn:VRRP.Advert.Ign> Slot-1: Advert for VR on vlan PR_CH_INT vrid 1 ignored: ignoring lower priority advert
08/01/2014 02:13:58.17 <Warn:VRRP.Advert.Ign> Slot-1: Advert for VR on vlan PR_MNL_EXT vrid 1 ignored: ignoring lower priority advert
08/01/2014 02:13:58.15 <Warn:VRRP.Advert.Ign> Slot-1: Advert for VR on vlan IL_OAM vrid 1 ignored: ignoring lower priority advert
thanks,
James
Photo of James Red
James Red
  • 322 Points 250 badge 2x thumb
Posted 4 years ago
Photo of Sumit Tokle
Sumit Tokle, Alum
  • 5,738 Points 5k badge 2x thumb
The reason for the above log
messages is “ignoring lower priority advert”, it means VRRP master switch is receving the hello packets from lower priority switch. This log messages appered when backup VRRP became Master and start sending Hello packets, however current master is still present in the network. It may be DUAL master condition here.
Photo of James Red
James Red
Thank you Sumit for your reply.
Other than the inter-extreme switch link(where vrrp passes) failing, what could be the reason for the back-up to become Master?
Sumit Tokle, Alum
VRRP hello packets are getting dropped
High CPU utilization
High port utilization
Congestion
Photo of James Red
James Red
Thank you for that information. It's nice to know that even High CPU and Port utilization can cause to VRRP failure.
