Air Ranger will not launch
  • Problem
  • Updated 2 years ago
  • Solved
  • (Edited)
Downloaded Air Ranger, installed, right click>Run as Administrator. Nothing. Why does Air Ranger not open? Java is installed and updated. Windows 10 OS. Tried it on two different laptops. Also does not work on MS Surface.
Photo of Jessica Serrette
Jessica Serrette
  • 100 Points 100 badge 2x thumb
Posted 2 years ago
Jessica Serrette
Update:
Called Extreme. It is not supported on windows 10, and was told there will be no update to make it supported.
There is one work around I found. It can be installed and running on a machine with a previous windows OS, and then the machine can be upgraded to windows 10 with Air Ranger still working. However, only for that user, other users cannot download air ranger afterwards and get it running.
Photo of Drew C.
Drew C., Community Manager
  • 40,858 Points 20k badge 2x thumb
Welcome to the Hub, Jessica!  And thanks for coming back to update the thread.  I'll see about making sure this limitation gets documented in our Knowledgebase.
