air ranger
  • Question
  • Updated 5 years ago
  • Answered
Hi I have downloaded the Air Ranger app but can't seem to install it. Is there any docs or help files to install from?
Photo of Robert Wills
Robert Wills
  • 130 Points 100 badge 2x thumb
Posted 5 years ago
Robert Wills
Hi all, simple fix, java was not installed on the machine. Solution - installed on a machine that had java, just need to combine that with wireless card and should be good..
Thanks
Photo of Tamera Rousseau-Vesta
Tamera Rousseau-Vesta, Extreme Alumna
  • 2,760 Points 2k badge 2x thumb
Hi Robert, I am glad that worked itself out for you! :-)
Robert Wills
Hi Tamera, another d.. I mean a doh moment, should have been obvious with the extension but.
Cheers
Robert
It happens to the best of us!  Those d'oh moments happen daily for me.  It was very nice of you to post  your resolution to your own problem! :-)  Thank you!!
