airprint randomly stops working
  • Problem
  • Updated 2 years ago
  • Not a Problem
this is a new identifi install with 4x4 APs
the legacy Meru install was working flawlessly
the airprint server disappears after an amount of time, turning the airprint server's wifi off then back on gets functionality back
multicast settings are set to allow all multicast traffic
not sure what to adjust to get airprint to continuously work
thanks!
I love this community!
Photo of Joe Kozura
Joe Kozura
  • 212 Points 100 badge 2x thumb
Posted 2 years ago
Photo of Ronald Dvorak
Ronald Dvorak, Embassador
  • 45,286 Points 20k badge 2x thumb
You should tell us a little bit more about the installation....
controller type, AP model, software version, setup of the WLAN service, topology used.
In case the used topology isn't bridge@AP could you give it a try with it to see whether you run into the same issue with this topology mode.
Photo of Joe Kozura
Joe Kozura
c35 controller, AP3935i, 10.11.03.0004, all wlans/topologies are bridged at ap
DTIM seemed pretty high to me at 5, lowered to 2.
Not sure if that will help or not.
Is there a specific setting to allow airplay / bonjour?  Perhaps disabling that and allowing all multicast traffic can fix it?
thanks for the reply
As you already use bridge@AP the traffic isn't passed thru the WLAN controller and there is no multicast settings that could affect/stop the traffic..... beside ACLs in the role but as it's working for sometimes the rule set should be OK.
Could you check if the server is reachable via ping if the issue arise again.
Photo of Joe Kozura
Joe Kozura
Here is a picture from the netsight server
Not sure why it is de-registering
maybe it is a bug?  I know the newest firmware addressed the exact same issue for some other devices, maybe this is still an issue with a mac os server?
You might see more information on the controller if you've station events enabled in > Controller > Logs > System Log Level > Report station events on controlller
If so you'd take a look in > Logs> Station Events > put in the MAC of the client in the field in the upper right corner to filter on that client
You should see the de-registration cause in the "additional detail" column.
My wild guess .... the cause is "idle-timeout" :-)
Photo of Joseph Burnsworth
Joseph Burnsworth
  • 2,328 Points 2k badge 2x thumb
Ive had this happen as well. I had to turn re-key interval on and to 3600 seconds under the auth tab. The authorization becomes stale. If you roam to an AP and back it'll also "Wake" it back up.
Photo of Joe Kozura
Joe Kozura
awesome! We'll give this a try, got some more feedback, if the wired port on the server is unplugged it works all the time
I'll let you know what happens
Joseph Burnsworth
i know this has been sitting for a min and the client may have moved forward, but i am thinking about this post i must have over looked, which i apologize for.
You say that when the server is unplugged from the network, it never stops working. What configs do you have on the switch for igmpsnooping? You wouldn't happen to have fast-leave on would you?
I've had that bite me in the rear as devices that went idle would "leave" and come back with fast-leave on.
Photo of Joe Kozura
Joe Kozura
Joseph, the broadcast re-key interval was already on and set to 3600 seconds
Ronald, I turned on station logging but haven't snagged anything yet on that station, logs are still writing to the netsight server but doesn't give me more details, we'll see if they have anymore issues with the wired port unplugged
I'll have him plug it back in Monday to see if we can break it again
Maybe setting up a ping sensor to the server's IP will keep it alive?
Photo of Joe Kozura
Joe Kozura
it was reported that the printer stopped working
looking at the station logs i'm still not seeing anything on the airprint server timing out, but in the active clients view, it has been connected for over 2 days
we offered to setup a ping sensor to the airprint server to try keep alive but the customer wants to go with a different solution to allow people to print
thanks for the help guys, I'll update this thread if the customer decides to continue troubleshooting the issue
Joseph Burnsworth
I had one other scenario with a client and ended setting up a script to reboot the AP's every night at 2am.
Let me know if you want to take that route, I'll give you the HUB link that I created for this
Photo of James A
James A, Embassador
  • 6,542 Points 5k badge 2x thumb
How long after reconnecting does the AirPrint server stay visible for? You can monitor Bonjour with this command on OS X:
dns-sd -B _ipp
Photo of Joe Kozura
Joe Kozura
thanks for the tips guys, the customer has implemented some kind of work around, I'm sure that your suggestions will help other people in the future, I'll put an update in here if they want to revisit it.
Photo of Ryan Mathews
Ryan Mathews, Alum
  • 8,988 Points 5k badge 2x thumb
Good stuff Joe.  Thanks for joining the Hub by the way.
Great to have you in the Extreme Community.
