AirRanger wont start - Can't create Java VM
Chris_Skerman
New Contributor II
Trying to launch AirRanger, and receive
EXCEPTION:
AirRanger.exe then crashes.
7 REPLIES 7
Chris_Skerman
New Contributor II
I found that downgrading my Java Version actually allowed Air Ranger to launch. At time of writing, v8u144 was the latest, I downgraded to 8u91. Air Ranger was then able to launch.
Jacob__Praveen
I did some online research on this issue and you could give the steps mentioned in this article a shot. http://www.tomshardware.com/answers/id-2174835/solve-java-error-create-java-virtual-machine.html
I had come across this too. It doesn't fix the issue.
Jacob__Praveen
Chris,
Do you still have this issue? Did you try upgrading Java to the latest?
