All APs are showing only 1 "Active Client" on the AP properties page even though their are many more clients connected.
  • Problem
  • Updated 2 years ago
  • Solved
We recently upgraded to 09.21.12.0005 and now every AP shows only 1 Active Client in the AP Properties window on the controller.  I'm running a pair of C5210 in HA with over a 1200 APs (mix of 3610, 3715 & 3825).  I've checked the different AP models and it's the same across the board.
If I pull up an Client Report by AP on the controller, I see all the clients.  Also, if I filter by AP name in OneView, I get all the clients.  It's only on the AP properties page that it's not reporting correctly.
Photo of Rich Pacheco
Rich Pacheco
  • 934 Points 500 badge 2x thumb
Posted 2 years ago
Photo of Jeremy
Jeremy, Embassador
  • 9,788 Points 5k badge 2x thumb
It's a bug, time to upgrade again.
Photo of Jason
Jason, Employee
  • 3,544 Points 3k badge 2x thumb
Hi Rich,
This is a bug we had in 9.21.12 and is fixed in our latest release, 9.21.13.
For reference - https://gtacknowledge.extremenetworks.com/articles/Solution/Active-clients-show-as-1-for-every-AP-in...
Thank you,
Jason
Photo of Nicolas Martinez
Nicolas Martinez
  • 160 Points 100 badge 2x thumb
Yes, it's a bug, confirmed.
Photo of Jeremy
Jeremy, Embassador
Just upgrade to the latest version of 9.21. I was on it for a few weeks before going to 10.11 code, which seems to be relatively stable.
Rich Pacheco
I'd like to go to 10 code but can't because of the 200+ 3610's that don't support it.  Working on replacing those soon.  Thanks again for the quick response.
Rich Pacheco
Thanks.. I guess my search skills need to be upgraded as well. :) Thanks for the quick responses.
-Rich P.
Photo of Ryan Mathews
Ryan Mathews, Alum
  • 8,988 Points 5k badge 2x thumb
Great to see the Hub community move so quickly for you Rich.
Unified Search at Extreme is highly effective and we're always trying to make it better.  We also try to be very friendly to Google in case your journey starts there.
We're happy when you get a resolution, no matter where it's is sourced from.  We want all these support channels to work for you.  Make not apologies about that!
Thanks for your trust in Extreme Networks.
