Altitude 4610 LEDs both solid.
  • Question
  • Updated 3 years ago
  • Answered
I have an Altitude 4610 AP that is not adopting and when I plug it in both LEDs stay solid. What does this mean? The installation manual does not mention both LEDs on solid. Thanks for any help.
Photo of Will
Will
  • 200 Points 100 badge 2x thumb
Posted 3 years ago
Photo of Brandon Clay
Brandon Clay, Escalation Support Engineer
  • 13,486 Points 10k badge 2x thumb
Hi William,
Both LEDs solid on meansĀ eitherĀ that the AP is booting, or it is adopted but not configured. Since it is not adopting, I suspect that this AP is stuck i the boot process and may need replacement. If you check the port statistics on the switch port it is connected to, I would not expect to see any packets received. In EXOS, this command would be 'show port <port#> statistics'. If the RX counter is not incrementing, I would suggest opening an RMA with GTAC.
-Brandon
Photo of Will
Will
Okay thank you for your response.
